Author Topic: find out the units thru lisp  (Read 1975 times)
viva
« on: August 17, 2006, 03:39:40 AM »
hi everybody,
                 i want  to find out the units of the drawing thru lisp. my requirement is to check the distance btween two polylines. if the distance is less than 25 meters, i want 2 place a circle . can anyone give me some idea to do the process.
regards
vivek
nivuahc
Re: find out the units thru lisp
« Reply #1 on: August 17, 2006, 07:21:03 AM »
(setq LinearUnits (getvar "LUNITS"))
1 = Scientific
2 = Decimal
3 = Engineering
4 = Architectural
5 = Fractional
(setq AngularUnits (getvar "AUNITS"))
0 = Decimal degrees
1 = Degrees/minutes/seconds
2 = Gradians
3 = Radians
4 = Surveyor's units
viva
« Reply #2 on: August 18, 2006, 02:22:49 AM »
hi nivuahc
         thanks for ur valuable information. it will help me alot.
regards
vivek
« Reply #3 on: August 18, 2006, 03:31:44 AM »
.. also
(IF (= 1 (GETVAR "MEASUREMENT"))
  "Metric"
  "Imperial"
