Basically what I have are several mleader routines that set the arrow heads (some of them set it to a dot if not pointing to an object) and also sets the content, in some cases these are specific blocks, in other cases it is just text, also on certain blocks pressing n will add a note bubble. It also sets the layer, arrowhead and text sizes per our standards.
What I am trying to do is combine these routines into one, where you press TAB to cycle between the different Arrowheads and Press space to cycle between the different types of content.
The LISP routine works fairly well, as far as I can tell so far, I only have two outstanding items:
- Fix this alignment issue (A pain in the neck)
- Make the routine work with polar tracking and ortho
If yhou have something that can accomplish this (even if some modifications are needed), that would be cool.
