Author Topic: Move Attributes About Insertion Point  (Read 6137 times)
M-dub
« on: October 26, 2010, 11:12:19 AM »
I have a dynamic block (one of very few in our library) that has a symbol with two or three attributes.  After inserting the block I want to be able to move the attributes as a group anywhere around the insertion point of the block within a certain radius (as shown by the hidden lines).  I don't want people to move the attributes TOO far from the symbol to which they are referring.
I'm nearly illiterate when it comes to dynamic blocks ( :( ) and need some help... with this.
Should I be using the Point parameter or XY... or neither?
Re: Move Attributes About Insertion Point
« Reply #1 on: October 26, 2010, 11:21:00 AM »
perhaps set an incremental stretch...and limit the allowable distance
M-dub
« Reply #2 on: October 26, 2010, 11:36:56 AM »
Nngg-Kay... Uhm...
When I try to do what I THINK I need to do to get there, I select the objects (the two attributes) and get "2 unlocked AttDefs filtered from selection".
What am I doing wrong or NOT doing right?
« Reply #3 on: October 26, 2010, 11:52:44 AM »
Try this one Mike .. the key to moving attributes is locking the position of them. (bear in mind I'm fairly d-block inept)  :-D
« Last Edit: October 26, 2010, 12:02:30 PM by ronjonp »
« Reply #4 on: October 26, 2010, 11:54:11 AM »
open in block editor...
add parameter
edit the parameter properties
adjust incremental-ness
be sure to select those objects in the stretch definition
M-dub
« Reply #5 on: October 26, 2010, 11:55:54 AM »
That's perfect!
Now, to go figure out how you did it!  :)
Thank-you VERY much!
M-dub
« Reply #6 on: October 26, 2010, 11:56:19 AM »
add parameter
Thanks a lot... Going to check this out again.
« Reply #7 on: October 26, 2010, 12:01:43 PM »
That's perfect!
No problem :)  I updated the post above with a different version that removes the grip from the insertion point.
