Author Topic: How to get code name from fas file  (Read 7692 times)
Adesu
« on: March 27, 2007, 11:13:13 PM »
Hi Alls,
This below code is a very simple,that code have name is "test",everybody of course known it,my problem is if that code to become a fas file,I can not know what name of the code, and is there a code to search name code from fas file?.
Lsp file
(defun c:test (/ p1 p2 p3 p4)
  (setq p1 '(0 0 0))
  (setq p2 '(10 0 0))
  (setq p3 '(10 5 0))
  (setq p4 '(0 5 0))
  (command "_pline" p1 p2 p3 p4 "c" "")
  )    ; defun
Fas file from above code
FAS4-FILE ; Do not change it!
118
16 $ Q
  Q
 Q
Q
Q
Q
Q
Q
5$
251 5 $ØÕ>u
/-|-+Fgk6LH#uu¨±Yd-j=FG Hb1\ÌÞt8k\IF
_D^`1XÌÕ?\|IBpd#CD =A4¥ºZ/Z)-1o B&C(V[Q1XþÞq82]\BuC#)9b[ÌoE
1o G-@QDlgOS1¢°ft^E]I%C\K? bjÿÔ?/Z)-1dCR hmXÌæ?/I'ytSG.BR ~%YÌÔ?} 'f]GG`1mÍÕ?u/1Kc¯{D0:'
;fas4 crunch
;$;A3/28/07
Re: How to get code name from fas file
« Reply #1 on: March 27, 2007, 11:21:32 PM »
Add something like this to the end of the file before you compile it
(PROMPT "\n  CommandLine : < MYSuperDuperProgram > [Build 20070328]\n")
Adesu
« Reply #2 on: March 29, 2007, 01:34:28 AM »
Hi Kerry,
My code now revised like this
  (setq p1 '(0 0 0))
  (setq p2 '(10 0 0))
  (setq p3 '(10 5 0))
  (setq p4 '(0 5 0))
  (prompt "\nCommandLine : (c:test)[Build 20070328]\n")
  )    ; defun
But I cat not see , what I looking for
« Reply #3 on: March 29, 2007, 02:04:04 AM »
Sorry, I meant like this ..So it shows when loading ..
  (setq p1 '(0 0 0))
  (setq p2 '(10 0 0))
  (setq p3 '(10 5 0))
  (setq p4 '(0 5 0))
)    ; defun
(prompt "\nCommandLine : < c:test >  [Build 20070328]\n")
SomeCallMeDave
« Reply #4 on: March 29, 2007, 08:00:49 AM »
If you create a VLX, you can add a text resource file to the compilation and you can include any data that you need.  It will be included at the bottom of the VLX in clear text
;fas4 crunch
;$;A3/28/07o7ADESU RESOURCE$#$#$#$#$
DATA you need goes HERE
Function Names --  c:Test
Or anything Else
$#$#$#$#$VRTLIB-1
Adesu
« Reply #5 on: March 29, 2007, 07:46:26 PM »
;fas4 crunch
Or anything Else
$#$#$#$#$VRTLIB-1
Yes it can do, my question is , are you creating that text with manual ?, or with add a lisp program.
Others question, if you have a lisp file in fas file, and you forgot what it name code then that code not yet add text as your suggest,how to know to call it
« Reply #6 on: March 29, 2007, 08:35:51 PM »
Open a new drawing, preferably without many commands loaded ..
At the command line :
Command: lsp
Enter an option [?/Commands/Functions/Variables/Load]: C
Enter Commands to list <*>: *
Load the VLX
Command: lsp
Compare the lists
Adesu
« Reply #7 on: March 29, 2007, 10:20:22 PM »
Here result I just check, at that list I can not find "test".
Command:
Command: lsp
Enter an option [?/Commands/Functions/Variables/Load]: c
-BLOCKREPLACE                 (SUBR)
-BLOCKTOXREF                  (SUBR)
-CDORDER                      (SUBR)
-COPYTOLAYER                  (SUBR)
-LAYOUTMERGE                  (SUBR)
-LMAN                         (SUBR)
-LMANMODE                     (SUBR)
-OVERKILL                     (SUBR)
-REDIRMODE                    (SUBR)
-TCASE                        (SUBR)
-XLIST                        (SUBR)
3D                            (SUBR)
3DARRAY                       (SUBR)
ACADINFO                      (SUBR)
ACETUCS-BACK                  (SUBR)
ACETUCS-BOTTOM                (SUBR)
ACETUCS-FRONT                 (SUBR)
ACETUCS-LEFT                  (SUBR)
ACETUCS-RIGHT                 (SUBR)
ACETUCS-TOP                   (SUBR)
ADDVARS2SCR                   (SUBR)
AI_BOX                        (SUBR)
AI_CONE                       (SUBR)
AI_CUSTOM_SAFE                (SUBR)
AI_DISH                       (SUBR)
AI_DOME                       (SUBR)
AI_MESH                       (SUBR)
AI_PRODUCT_SUPPORT            (SUBR)
AI_PRODUCT_SUPPORT_SAFE       (SUBR)
AI_PYRAMID                    (SUBR)
AI_SELALL                     (SUBR)
AI_SPHERE                     (SUBR)
AI_TORUS                      (SUBR)
AI_TRAINING_SAFE              (SUBR)
AI_WEDGE                      (SUBR)
ALIASEDIT                     (SUBR)
ALIGNSPACE                    (SUBR)
ARCTEXT                       (SUBR)
ATEXT                         (SUBR)
ATTIN                         (SUBR)
ATTOUT                        (SUBR)
ATTREDEF                      (SUBR)
BCOUNT                        (SUBR)
BEXTEND                       (SUBR)
BLOCK?                        (SUBR)
BLOCKREPLACE                  (SUBR)
BLOCKTOXREF                   (SUBR)
BREAKLINE                     (SUBR)
BSCALE                        (SUBR)
BTRIM                         (SUBR)
BURST                         (SUBR)
CDORDER                       (SUBR)
CHSPACE                       (SUBR)
CHURLS                        (SUBR)
CLIPIT                        (SUBR)
CLOSEALL                      (SUBR)
COPYM                         (SUBR)
COPYTOLAYER                   (SUBR)
DATE                          (SUBR)
DDEMODES                      (SUBR)
DDGRIPS                       (SUBR)
DDRMODES                      (SUBR)
DDSELECT                      (SUBR)
DIMEX                         (SUBR)
DIMIM                         (SUBR)
DIMREASSOC                    (SUBR)
DIMSIO                        (SUBR)
EDGE                          (SUBR)
EDITTIME                      (SUBR)
ETBUG                         (SUBR)
EXOFFSET                      (SUBR)
EXPLAN                        (SUBR)
EXPRESSMENU                   (SUBR)
EXPRESSREG                    (SUBR)
EXPRESSTOOLS                  (SUBR)
EXTRIM                        (SUBR)
FASTSEL                       (SUBR)
FLATTEN                       (SUBR)
FS                            (SUBR)
FSCREEN                       (SUBR)
FSMODE                        (SUBR)
FULLSCREEN                    (SUBR)
GATTE                         (SUBR)
GETSEL                        (SUBR)
GIFIN                         (SUBR)
GOTOURL                       (SUBR)
IMAGEAPP                      (SUBR)
IMAGEEDIT                     (SUBR)
IMAGEOVERLAP                  (SUBR)
LAP                           (SUBR)
LAYCUR                        (SUBR)
LAYDEL                        (SUBR)
LAYFRZ                        (SUBR)
LAYISO                        (SUBR)
LAYLCK                        (SUBR)
LAYMCH                        (SUBR)
LAYMRG                        (SUBR)
LAYOFF                        (SUBR)
LAYON                         (SUBR)
LAYOUTMERGE                   (SUBR)
LAYTHW                        (SUBR)
LAYULK                        (SUBR)
LAYUNISO                      (SUBR)
LAYVPI                        (SUBR)
LAYVPMODE                     (SUBR)
LAYWALK                       (SUBR)
LMAN                          (SUBR)
LMANMODE                      (SUBR)
LSP                           (USUBR)
LSPDUMP                       (SUBR)
LSPSURF                       (SUBR)
MKLTYPE                       (SUBR)
MKSHAPE                       (SUBR)
MOCORO                        (SUBR)
MOVEBAK                       (SUBR)
MPEDIT                        (SUBR)
MSTRETCH                      (SUBR)
MVSETUP                       (SUBR)
NCOPY                         (SUBR)
OVERKILL                      (SUBR)
PCXIN                         (SUBR)
PLT2DWG                       (SUBR)
PROPULATE                     (SUBR)
PSBSCALE                      (SUBR)
PSFILL                        (EXRXSUBR)                    Core
PSTSCALE                      (SUBR)
QLATTACH                      (SUBR)
QLATTACHSET                   (SUBR)
QLDETACHSET                   (SUBR)
QQUIT                         (SUBR)
REBUILD-EXPRESS-MENU          (SUBR)
REDIR                         (SUBR)
REDIRMODE                     (SUBR)
REPURLS                       (SUBR)
REVERT                        (SUBR)
RTEDIT                        (SUBR)
RTEXT                         (SUBR)
RTEXTAPP                      (SUBR)
RTUCS                         (SUBR)
SAVEALL                       (SUBR)
SHOWURLS                      (SUBR)
SHP2BLK                       (SUBR)
SSX                           (SUBR)
SUPERHATCH                    (SUBR)
SYSVDLG                       (SUBR)
TCASE                         (SUBR)
TCIRCLE                       (SUBR)
TCOUNT                        (SUBR)
TEDIT                         (SUBR)
TEXTFIT                       (SUBR)
TEXTMASK                      (SUBR)
TEXTUNMASK                    (SUBR)
TFHELP                        (SUBR)
TFRAMES                       (SUBR)
TIFFIN                        (SUBR)
TJUST                         (SUBR)
TORIENT                       (SUBR)
TREX                          (SUBR)
TSCALE                        (SUBR)
TSPACEINVADERS                (SUBR)
TUTCLEAR                      (SUBR)
TUTDEMO                       (SUBR)
TXT2MTXT                      (SUBR)
TXTEXP                        (SUBR)
VARS2SCR                      (SUBR)
VLIDE                         (SUBR)                        Core
VPSCALE                       (SUBR)
VPSYNC                        (SUBR)
XDATA                         (SUBR)
XDLIST                        (SUBR)
XLIST                         (SUBR)
Command:
Command: 'VLIDE
Command:
Command:
Command:
Command: _appload Test.fas was added to the Startup Suite.
Command:
Command:
Command: lsp
-BLOCKTOXREF                  (SUBR)
-CDORDER                      (SUBR)
-COPYTOLAYER                  (SUBR)
-LAYOUTMERGE                  (SUBR)
-LMAN                         (SUBR)
-LMANMODE                     (SUBR)
-OVERKILL                     (SUBR)
-REDIRMODE                    (SUBR)
-TCASE                        (SUBR)
-XLIST                        (SUBR)
3D                            (SUBR)
3DARRAY                       (SUBR)
ACADINFO                      (SUBR)
ACETUCS-BACK                  (SUBR)
ACETUCS-LEFT                  (SUBR)
ACETUCS-TOP                   (SUBR)
ADDVARS2SCR                   (SUBR)
AI_BOX                        (SUBR)
AI_CONE                       (SUBR)
AI_DISH                       (SUBR)
AI_DOME                       (SUBR)
AI_MESH                       (SUBR)
AI_PYRAMID                    (SUBR)
AI_SELALL                     (SUBR)
AI_SPHERE                     (SUBR)
AI_TORUS                      (SUBR)
AI_WEDGE                      (SUBR)
ALIASEDIT                     (SUBR)
ALIGNSPACE                    (SUBR)
ARCTEXT                       (SUBR)
ATEXT                         (SUBR)
ATTIN                         (SUBR)
ATTOUT                        (SUBR)
ATTREDEF                      (SUBR)
BCOUNT                        (SUBR)
BEXTEND                       (SUBR)
BLOCK?                        (SUBR)
BLOCKREPLACE                  (SUBR)
BLOCKTOXREF                   (SUBR)
BREAKLINE                     (SUBR)
BSCALE                        (SUBR)
BTRIM                         (SUBR)
BURST                         (SUBR)
CDORDER                       (SUBR)
CHSPACE                       (SUBR)
CHURLS                        (SUBR)
CLIPIT                        (SUBR)
CLOSEALL                      (SUBR)
COPYM                         (SUBR)
COPYTOLAYER                   (SUBR)
DATE                          (SUBR)
DDEMODES                      (SUBR)
DDGRIPS                       (SUBR)
DDRMODES                      (SUBR)
DDSELECT                      (SUBR)
DIMEX                         (SUBR)
DIMIM                         (SUBR)
DIMREASSOC                    (SUBR)
DIMSIO                        (SUBR)
EDGE                          (SUBR)
EDITTIME                      (SUBR)
ETBUG                         (SUBR)
EXOFFSET                      (SUBR)
EXPLAN                        (SUBR)
EXPRESSMENU                   (SUBR)
EXPRESSREG                    (SUBR)
EXPRESSTOOLS                  (SUBR)
EXTRIM                        (SUBR)
FASTSEL                       (SUBR)
FLATTEN                       (SUBR)
FS                            (SUBR)
FSCREEN                       (SUBR)
FSMODE                        (SUBR)
FULLSCREEN                    (SUBR)
GATTE                         (SUBR)
GETSEL                        (SUBR)
GIFIN                         (SUBR)
GOTOURL                       (SUBR)
IMAGEAPP                      (SUBR)
IMAGEEDIT                     (SUBR)
IMAGEOVERLAP                  (SUBR)
LAP                           (SUBR)
LAYCUR                        (SUBR)
LAYDEL                        (SUBR)
LAYFRZ                        (SUBR)
LAYISO                        (SUBR)
LAYLCK                        (SUBR)
LAYMCH                        (SUBR)
LAYMRG                        (SUBR)
LAYOFF                        (SUBR)
LAYON                         (SUBR)
LAYOUTMERGE                   (SUBR)
LAYTHW                        (SUBR)
LAYULK                        (SUBR)
LAYUNISO                      (SUBR)
LAYVPI                        (SUBR)
LAYVPMODE                     (SUBR)
LAYWALK                       (SUBR)
LMAN                          (SUBR)
LMANMODE                      (SUBR)
LSP                           (USUBR)
LSPDUMP                       (SUBR)
LSPSURF                       (SUBR)
MKLTYPE                       (SUBR)
MKSHAPE                       (SUBR)
MOCORO                        (SUBR)
MOVEBAK                       (SUBR)
MPEDIT                        (SUBR)
MSTRETCH                      (SUBR)
MVSETUP                       (SUBR)
NCOPY                         (SUBR)
OVERKILL                      (SUBR)
PCXIN                         (SUBR)
PLT2DWG                       (SUBR)
PROPULATE                     (SUBR)
PSBSCALE                      (SUBR)
PSTSCALE                      (SUBR)
QLATTACH                      (SUBR)
QLATTACHSET                   (SUBR)
QLDETACHSET                   (SUBR)
QQUIT                         (SUBR)
REDIR                         (SUBR)
REDIRMODE                     (SUBR)
REPURLS                       (SUBR)
REVERT                        (SUBR)
RTEDIT                        (SUBR)
RTEXT                         (SUBR)
RTEXTAPP                      (SUBR)
RTUCS                         (SUBR)
SAVEALL                       (SUBR)
SHOWURLS                      (SUBR)
SHP2BLK                       (SUBR)
SSX                           (SUBR)
SUPERHATCH                    (SUBR)
SYSVDLG                       (SUBR)
TCASE                         (SUBR)
TCIRCLE                       (SUBR)
TCOUNT                        (SUBR)
TEDIT                         (SUBR)
TEXTFIT                       (SUBR)
TEXTMASK                      (SUBR)
TEXTUNMASK                    (SUBR)
TFHELP                        (SUBR)
TFRAMES                       (SUBR)
TIFFIN                        (SUBR)
TJUST                         (SUBR)
TORIENT                       (SUBR)
TREX                          (SUBR)
TSCALE                        (SUBR)
TUTCLEAR                      (SUBR)
TUTDEMO                       (SUBR)
TXT2MTXT                      (SUBR)
TXTEXP                        (SUBR)
VARS2SCR                      (SUBR)
VLIDE                         (SUBR)                        Core
VPSCALE                       (SUBR)
VPSYNC                        (SUBR)
XDATA                         (SUBR)
XDLIST                        (SUBR)
XLIST                         (SUBR)
« Last Edit: March 29, 2007, 10:22:38 PM by Adesu »
« Reply #8 on: March 29, 2007, 10:29:41 PM »
Mine ...
Command: lsp
Enter Commands to list <*>: t*
T25                           (SUBR)
T30                           (SUBR)
T35                           (SUBR)
T50                           (SUBR)
T70                           (SUBR)
T90                           (SUBR)
TBH                           (SUBR)
TCASE                         (SUBR)
TCIRCLE                       (SUBR)
TCOUNT                        (SUBR)
TEST                          (SUBR)
TEXTFIT                       (SUBR)
TEXTMASK                      (SUBR)
TEXTUNMASK                    (SUBR)
TFHELP                        (SUBR)
Adesu
« Reply #9 on: March 29, 2007, 10:42:44 PM »
Hi Kerry,
I more interest it with your info,but in my cad allways I can not got as I looking for,I don't know what happend it.
if I load my fas file,I got this message, what is meaning
; error: bad character read (octal): 24
_$
« Reply #10 on: March 29, 2007, 10:53:58 PM »
Hi Kerry,
_$
I don't know what would cause that. Have you edited the FAs/VLx file ?
but you do have extra "" in PLINE command
should be
  (command "_pline" p1 p2 p3 p4 "c" )
not
Adesu
« Reply #11 on: March 29, 2007, 11:20:22 PM »
You are right,thanks for your correction.
and I just tested as suggest "SomeCallMeDave", it's great "TRICK" ,look at this
Command: test
_pline
Specify start point:
Current line-width is 0.0000
Specify next point or [Arc/Halfwidth/Length/Undo/Width]:
Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]:
Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]: c
Command:
nil
This is good trick to add a text the end of fas file.
;fas4 crunch
Or anything Else
$#$#$#$#$VRTLIB-1
