But my knowledge of lisp and DCL is very small.
Try this one...
AIA Layer v3.lyrAIA Layer v3 EXST.lyrAIA Layer v3 NEWW.lyrLAYER_CREATOR.dclLAYER_CREATOR.lspLAYER_CREATOR.slb
Command: lc ; error: Automation Error. No database
Quote from: TimSpangler on March 21, 2011, 12:45:01 PMTry this one...Dear Sir,Error on lisp use autocad 2006copy all autocad support folder Code: [Select]AIA Layer v3.lyrAIA Layer v3 EXST.lyrAIA Layer v3 NEWW.lyrLAYER_CREATOR.dclLAYER_CREATOR.lspLAYER_CREATOR.slbQuoteCommand: lc ; error: Automation Error. No database
There should be a file named "Layer Files" in the same folder as the LayerCreator.lsp. This file will/should contain all of the .lyr files.Try that.Quote from: Sam on March 22, 2011, 06:51:19 AMQuote from: TimSpangler on March 21, 2011, 12:45:01 PMTry this one...Dear Sir,Error on lisp use autocad 2006copy all autocad support folder Code: [Select]AIA Layer v3.lyrAIA Layer v3 EXST.lyrAIA Layer v3 NEWW.lyrLAYER_CREATOR.dclLAYER_CREATOR.lspLAYER_CREATOR.slbQuoteCommand: lc ; error: Automation Error. No database
