Author Topic: Assembly Test Request  (Read 7773 times)
TR
« on: January 22, 2007, 08:04:01 PM »
Can anyone with .NET 2.0 Runtime and a version of AutoCAD greater than 2005 installed test an assembly for me? I compiling against the 2005 versions of the managed dll files and am wondering if anyone else can use them, mainly since the method of writing to the command line has changed between 2005 and future versions.
To Run:
* netload the PyAcadDotNet.dll
* issue the pyfile command
* browse to the folder you unziped to and select print.py
If you see a bunch of text strings dumped onto the commandline then it worked. If not please let me know. I'm doing some trickery to automatically add the AutoCAD managed dlls as references in python so that may be screwing things up.
Here is the source code for the dll if anyone is interested.
PyAcadDotNet.cs
Copyright (c) 2005, Tim Riley (riltim@gmail.com)
All rights reserved.
Redistribution and use in source and binary forms, with or without modification, are
permitted provided that the following conditions are met:
- Redistributions of source code must retain the above copyright notice, this list
  of conditions and the following disclaimer.
- Redistributions in binary form must reproduce the above copyright notice, this list
  of conditions and the following disclaimer in the documentation and/or other materials
  provided with the distribution.
- Neither the name Tim Riley nor the names of its contributors may be used to
  endorse or promote products derived from this software without specific prior written
  permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS &AS IS& AND ANY EXPRESS
OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY
AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
using System;
using System.Collections;
using System.Windows.Forms;
using System.IO;
using System.Text;
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Interop.Common;
using IronPython.Hosting;
namespace PyAcadDotNet
   public class AcadInterface : IExtensionApplication
       public Autodesk.AutoCAD.ApplicationServices.Application AcadApplication;
        public void Initialize()
            CommandLinePrompts.Message("\nPyAcad.NET Loaded Successfully....");
            CommandLinePrompts.Message("\ntype 'pyhelp' for commands....");
        public void Terminate()
        //nothing to see here.
        delegate void AddReference(object assembly);
       [CommandMethod("pyfile", CommandFlags.Session)]
       public void pythonfile()
        // Create a new instance of PythonEngine and set variables.
        PythonEngine engine = new PythonEngine();
        engine.AddToPath(Environment.CurrentDirectory);
        // Send Stdout and Stderr to the AutoCAD command line.
        engine.SetStandardOutput(new AcadCommandLine());
        engine.Import("clr");
        //lets load some AutoCAD assemblies.
        AddReference adr = engine.CreateMethod<AddReference>("clr.AddReference(assembly)");
        adr(typeof(BlockTableRecord).Assembly);
        adr(typeof(Editor).Assembly);
        // Display an OpenFileDialog and run the script.
    OpenFileDialog ofd = new OpenFileDialog();
    ofd.Filter = "Python files (*.py)|*.py|All files (*.*)|*.*" ;
    ofd.ShowDialog();
    // Run the file selected by the open file dialog box.
    //engine.ExecuteFile(ofd.FileName);
    CompiledCode cc = engine.CompileFile(ofd.FileName);
    cc.Execute();
   class AcadCommandLine : Stream
    //Modified version of a class coded by Mike Stall.
        #region unsupported Read + Seek members
        public override bool CanRead
            get { return false; }
        public override bool CanSeek
        public override bool CanWrite
            get { return true; }
        public override void Flush()
            // nop
        public override long Length
            get { throw new NotSupportedException("Seek not supported"); } // can't seek
        public override long Position
            get
                throw new NotSupportedException("Seek not supported");  // can't seek
            set
        public override int Read(byte[] buffer, int offset, int count)
            throw new NotSupportedException("Reed not supported"); // can't read
        public override long Seek(long offset, SeekOrigin origin)
        public override void SetLength(long value)
        #endregion
        public override void Write(byte[] buffer, int offset, int count)
            // Very bad hack: Ignore single newline char. This is because we expect the newline is following
            // previous content and we already placed a newline on that.
            if (count == 1 && buffer[offset] == '\n')
                return;
            StringBuilder sb = new StringBuilder();
            while (count > 0)
                char ch = (char) buffer[offset];
                if (ch == '\n')
                    CommandLinePrompts.Message(sb.ToString() + "\n");
                    sb.Length = 0; // reset.
                else if(ch != '\r')
                    sb.Append(ch);
                offset++;
                count--;
          if (sb.Length > 0)
                CommandLinePrompts.Message(sb.ToString()+ "\n");
Re: Assembly Test Request
« Reply #1 on: January 22, 2007, 08:28:01 PM »
Command: NETLOAD
Command: pyfile
Unknown command "PYFILE".  Press F1 for help.
in AC2007.
.. and your Initialize method did not execute.
« Reply #2 on: January 22, 2007, 08:31:44 PM »
I tried it in 2006 with no luck, it was looking for the earlier version of the acad assemblies which was no suprise (attached output). All things being ok it should work in 2005 though (which I don't have installed sorry).
Good Luck.
- John Carmack
- J.R.R. Tolkien
« Reply #3 on: January 22, 2007, 08:36:48 PM »
not in AC2007 or AC2006
but works in AC2005 ..
Command: netload
Command: pyhelp
Unknown command "PYHELP".  Press F1 for help.
Command: pyfile
Command: pyfile
This is a test
This is also a test
4
Word
387420489
4.5
« Reply #4 on: January 22, 2007, 08:49:19 PM »
Got this in 2007 with vs 2005
This is a test
This is also a test
4
Word
387420489
4.5
attached the solution
« Last Edit: January 22, 2007, 08:51:32 PM by Danielm103 »
« Reply #5 on: January 22, 2007, 08:55:57 PM »
hey ! .. that's cheating !! :lol:
« Reply #6 on: January 22, 2007, 08:57:54 PM »
 I only added your code  :-D
using AcEd = Autodesk.AutoCAD.EditorInput;
« Reply #7 on: January 22, 2007, 09:23:13 PM »
.. ;-) and a small recompile using the AC2007 references I 'spose ?
« Reply #8 on: January 22, 2007, 10:05:41 PM »
Busted,  :oops:
Sorry Tim, I didn’t mean to cheat, I just wanted to play with your python stuff.
Dan
TR
« Reply #9 on: January 22, 2007, 11:48:16 PM »
Thanks for all the testing guys. I am really looking to get this project back on it's feet and I would appreciate any help I can get. My main problem is I'm stuck with 2005 and I'd like to get this running with the newer versions of AutoCAD.
TR
« Reply #10 on: January 23, 2007, 12:51:01 AM »
So is it possible for me to create an assembly that can be compiled against any version of AutoCAD's managed dlls? Perhaps something similiar to C's ifdef statement or something?
« Reply #11 on: January 23, 2007, 12:56:42 AM »
That would be a feat! You may be able to do it by using ifdef's but you will still need to write different code for the different acad versions anyway and you would need to call in the references in your code instead of just importing them into your project which 'may' be easy enough.
I haven't looked at the 2007 api yet but I don't think there are too many changes from 2006 except for using .net 2 perhaps but 2005 should never have been released as a 'dependable' api, it did change considerably on the face of it once you start looking, teething problems I expect :)
- John Carmack
- J.R.R. Tolkien
TR
« Reply #12 on: January 23, 2007, 01:15:10 AM »
I'm doing very little interaction with the AutoCAD environment, mainly just mapping between the two. Which requires very little calls to the AutoCAD api.
If anyone is interested in hacking on this project I have created a svn repository. You can access it via:
svn checkout http://pyacaddotnet.googlecode.com/svn/trunk/ pyacaddotnet. If you have a google account I will give you commit access.
Project page is: http://code.google.com/p/pyacaddotnet/
Note: I'm using SharpDevelop so I'm not sure how this will interact with VS.
« Last Edit: January 23, 2007, 01:19:28 AM by Tim Riley »
TR
« Reply #13 on: January 23, 2007, 01:23:29 PM »
If anyone would be so kind as to run the following files through PyAcadDotNet for me it would be greatly appriciated. Note, you can open these with notepad to see that there is nothing harmful going on in them.
« Reply #14 on: January 23, 2007, 01:43:01 PM »
here's what I had with the solution built for 2007
Dan
« Last Edit: January 23, 2007, 01:46:42 PM by Danielm103 »
