Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Remove extra Vertices from polyline
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Remove extra Vertices from polyline (Read 1043 times)
PM
Guest
on:
December 08, 2022, 08:11:14 AM »
Hi. I am using this code to delete extra vetrices from polyline. I want to ask two things
1) Is it possible to select more than one polyline a time ?
2) I have a drawing like the attach file with close polylines. I can not unerstand why some vertex not deleted. I want to keep only the vertex at the edges of each polygon not on sections with
other ? Is any way to update the code to delete extra verteces on staight "line"?
Code - Auto/Visual Lisp:
[Select]
defun
c:PSimple
doc ent elst vlst idx dir keep result hlst len
group_on
vl-load-com
;; CAB 11/03/07
;; group on the elements of a flat list
;; (group_on '(A B C D E F G) 3)
;; Result ((A B C) (D E F) (G nil nil)...)
defun
group_on
inplst gp#
outlst idx subLst
while
inplst
setq
idx
1
subLst
nil
while
setq
idx
1+
idx
gp#
setq
subLst
cons
nth
idx inplst
sublst
setq
outlst
cons
reverse
sublst
outlst
repeat
gp#
setq
inplst
cdr
inplst
reverse
outlst
setq
doc
vla-get-ActiveDocument
vlax-get-acad-object
vla-StartUndoMark
doc
setq
ent
car
entsel
\n
Επιλέξτε την polyline για διαγραφή των extra vertex: "
if
and
ent
setq
elst
entget
ent
equal
assoc
0
elst
0
"LWPOLYLINE"
progn
setq
idx
0
repeat
fix
vlax-curve-getendparam
ent
cond
null
keep
setq
keep '
1
dir
angle
0
0
vlax-curve-getFirstDeriv
ent
0.0
or
null
ent idx
equal
dir
setq
dir
angle
0
0
ent idx
0.000001
setq
keep
cons
0
keep
setq
keep
cons
1
keep
setq
idx
1+
idx
setq
vlst
vl
remove
if
not
lambda
x
vl-position
car
x
40
41
42
10
elst
setq
vlst
group_on vlst
4
setq
idx
1
len
1-
length
vlst
keep
reverse
cons
1
keep
while
setq
idx
1+
idx
len
cond
not
zerop
cdr
cadddr
nth
idx vlst
; keep arcs
setq
result
cons
nth
idx vlst
result
not
zerop
nth
idx keep
setq
result
cons
nth
idx vlst
result
setq
hlst
vl
remove
if
lambda
x
vl-position
car
x
40
41
42
10
elst
mapcar
lambda
x
setq
hlst
append
hlst x
reverse
result
setq
hlst
subst
cons
90
length
result
assoc
90
hlst
hlst
entmod
hlst
vla-EndUndoMark
doc
princ
Logged
Needs a day job
Re: Remove extra Vertices from polyline
Reply #1 on:
December 08, 2022, 09:36:30 AM »
Have you seen this?
http://www.theswamp.org/index.php?topic=19865.msg244892#msg244892
Logged
PM
Guest
Reply #2 on:
December 08, 2022, 10:57:41 AM »
Thanks r
onjonp
. This code works fine !!!
[Select]
;; Purge-Pline (gile) 2007/11/25
;; Removes all superfluous vertex (overwritten, colinear or concentric)
;; Keeps arcs and widths
;; Keeps aligne vertices which show a width break
;; Closes pline which start point and end point are overwritten
defun
purge
pline
pl
regular
width colinear concentric
del
cadr
pour
car
elst closed old
p old
b
old
sw old
ew new
d new
p new
b new
sw
new
ew b1 b2
;; Evaluates if the pline width is regular on 3 successive points
defun
regular
width
p1 p2 p3 ws1 we1 ws2 we2
delta
or
ws1 we1 ws2 we2
and
we1 ws2
0
setq
delta
we2 ws1
equal
vlax-curve-getDistAtPoint
pl
trans
p2 pl
0
pl
trans
p1 pl
0
pl
trans
p3 pl
0
pl
trans
p1 pl
0
we1
we2 delta
delta
1e
9
;; Evaluates if 3 successive vertices are aligned
defun
colinear
p1 p2 p3 b1 b2
and
zerop
b1
zerop
b2
null
inters
p1 p2 p1 p3
;; Evaluates if 3 sucessive vertices have the same center
defun
concentric
p1 p2 p3 b1 b2
bd1 bd2
if
and
0.0
b1
0.0
b2
equal
caddr
setq
bd1
BulgeData b1 p1 p2
caddr
setq
bd2
BulgeData b2 p2 p3
1e
9
tan
car
bd1
car
bd2
4.0
;; Removes the second item of the list
defun
del
cadr
lst
set
lst
cons
car
eval
lst
cddr
eval
lst
;; Pours the first item of a list to another one
defun
pour
car
from to
set
to
cons
car
eval
from
eval
to
set
from
cdr
eval
from
setq
elst
entget
pl
and
1
logand
1
cdr
assoc
70
elst
setq
closed T
mapcar
function
lambda
x
cond
car
x
10
setq
old
p
cons
x old
p
car
x
40
setq
old
sw
cons
x old
sw
car
x
41
setq
old
ew
cons
x old
ew
car
x
42
setq
old
b
cons
x old
b
T
setq
new
d
cons
x new
d
elst
mapcar
function
lambda
l
set
l
reverse
eval
l
old
p old
sw old
ew old
b new
d
and
closed
setq
old
p
append
old
p
list
car
old
p
and
equal
cdar
old
p
cdr
last
old
p
1e
9
setq
closed T
new
d
subst
cons
70
Boole
7
cdr
assoc
70
new
d
1
assoc
70
new
d
new
d
while
cddr
old
p
if
regular
width
cdar
old
p
cdadr
old
p
cdaddr
old
p
cdar
old
sw
cdar
old
ew
cdadr
old
sw
cdadr
old
ew
cond
colinear
cdar
old
p
cdadr
old
p
cdaddr
old
p
cdar
old
b
cdadr
old
b
mapcar
'del
cadr
old
p old
sw old
ew old
b
setq
bu
concentric
cdar
old
p
cdadr
old
p
cdaddr
old
p
cdar
old
b
cdadr
old
b
setq
old
b
cons
cons
42
bu
cddr
old
b
mapcar
'del
cadr
old
p old
sw old
ew
T
mapcar
'pour
car
old
p old
sw old
ew old
b
new
p new
sw new
ew new
b
mapcar
'pour
car
old
p old
sw old
ew old
b
new
p new
sw new
ew new
b
if
closed
setq
new
p
reverse
cons
car
old
p
new
p
setq
new
p
append
reverse
new
p
old
p
mapcar
function
lambda
new old
set
new
append
reverse
eval
new
eval
old
new
sw new
ew new
b
old
sw old
ew old
b
if
and
closed
regular
width
cdr
last
new
p
cdar
new
p
cdadr
new
p
cdr
last
new
sw
cdr
last
new
ew
cdar
new
sw
cdar
new
ew
cond
colinear
cdr
last
new
p
cdar
new
p
cdadr
new
p
cdr
last
new
b
cdar
new
b
mapcar
function
lambda
l
set
l
cdr
eval
l
new
p new
sw new
ew new
b
setq
bu
concentric
cdr
last
new
p
cdar
new
p
cdadr
new
p
cdr
last
new
b
cdar
new
b
setq
new
b
cdr
reverse
cons
cons
42
bu
cdr
reverse
new
b
mapcar
function
lambda
l
set
l
cdr
eval
l
new
p new
sw new
ew
entmod
append
new
d
apply
append
apply
mapcar
cons
list
list
new
p new
sw new
ew new
b
;; BulgeData Retourne les donnees d'un polyarc (angle rayon centre)
defun
BulgeData
bu p1 p2
ang rad cen
setq
ang
2
atan
bu
rad
distance
p1 p2
2
sin
ang
cen
polar
p1
angle
p1 p2
pi
2
ang
rad
list
ang
2.0
rad cen
;; TAN Retourne la tangente de l'angle
defun
tan
ang
sin
ang
cos
ang
;; SPL Calling function
defun
c:spl
ss n pl
vl-load-com
or
acad
setq
acad
or
acdoc
setq
acdoc
acad
princ
\n
Select les polylines to be treated or <All>: "
or
setq
ss
ssget
0
"LWPOLYLINE"
setq
ss
ssget
"_X"
0
"LWPOLYLINE"
if
ss
progn
vla-StartUndoMark
acdoc
setq
n
1
while
setq
pl
ssname
ss
setq
n
1+
n
purge
pline pl
princ
strcat
\n
\t
itoa
n
" treated polyline(s)."
vla-EndUndoMark
acdoc
princ
\n
None selected polyline."
princ
princ
\n
Simp-Pline loaded, type SPL to launch the function."
princ
Logged
dgpuertas
Newt
Reply #3 on:
December 09, 2022, 07:49:17 AM »
another:
http://www.theswamp.org/index.php?topic=57443.15
for:
https://en.wikipedia.org/wiki/Ramer%E2%80%93Douglas%E2%80%93Peucker_algorithm
Logged
Crank
Water Moccasin
Reply #4 on:
December 09, 2022, 01:13:54 PM »
Or use the OVERKILL command
Logged
Vault Professional 2023 + AEC Collection
jvillarreal
Bull Frog
Reply #5 on:
December 09, 2022, 05:45:16 PM »
Or WEEDFEATURES if you have Civil 3D
Logged
mhupp
Bull Frog
Reply #6 on:
December 09, 2022, 10:26:34 PM »
This is more a manual lisp to pick a vertex you want to delete.
https://forums.autodesk.com/t5/autocad-forum/vertex-removal-lisp/m-p/4486299/highlight/true#M33618
Logged
MSTG007
Gator
I can't remeber what I already asked! I need help!
Reply #7 on:
December 12, 2022, 07:51:34 AM »
piggy back on mhupp,
Civil3D you can use the Delete Elevation Point within the Ribbon. or the command: _AeccDeleteFeaturePI
Works with Feature Lines, 3D Polylines, and Polylines.
Logged
Civil3D 2020
Print
Pages: [
1
Go Up
« previous
next »
Code Red
Topic:
