Author Topic: AutoCAD 2016  (Read 8826 times)
AutoCAD 2016
« on: March 20, 2015, 08:42:40 AM »
http://lynn.blogs.com/lynn_allens_blog/2015/03/introducingautocad-2016-part-one.html
AutoCAD 2016 is locked and loaded - coming soon to a reseller near you!  Here is an early look at some of the key features in the next (Awesome) release of AutoCAD!
I can hardly wait
Re: AutoCAD 2016
« Reply #1 on: March 20, 2015, 08:43:00 AM »
Bug fixes?
Re: AutoCAD 2016
« Reply #2 on: March 20, 2015, 08:52:50 AM »
Bug fixes?
Probably more bugs than fixes; this is Autodesk we are talking about here.
dtkell
Re: AutoCAD 2016
« Reply #3 on: March 23, 2015, 10:45:46 AM »
A whole new set of unimaginable bugs most likely.
But we will get used to them, find our work arounds and muddle on as per usual.
\"What sane person could live in this world and not be crazy?\" -Ursula K. Le Guin
MexicanCustard
Re: AutoCAD 2016
« Reply #4 on: March 23, 2015, 02:19:14 PM »
Kean has a little more info
Keans Autocad 2016
He also has some developer info
Keans Autocad 2016 for Developers
Still doesn't justify the cost of a subscription.
Re: AutoCAD 2016
« Reply #5 on: March 23, 2015, 03:04:28 PM »
The PDF Underlay speed improvement alone is worth it to me. I have one drawing with a number of details from a structural engineer that must be included with our plans. The sheets these are in are extremely slow to work with in 2013-2015. With 2016, I barely notice a difference between the drawings with or without pdf's.
Re: AutoCAD 2016
« Reply #6 on: March 23, 2015, 03:08:55 PM »
I just tested the PDF performance and it's quite a bit better than 2015 :)
cadtag
Re: AutoCAD 2016
« Reply #7 on: March 23, 2015, 04:59:56 PM »
Bear in mind that next year the only way to get Acad is with a subscription, either buy now and get on maintenance subscription to keep a permanent license, of pay by the month to keep operating.
yes, it's called rent-seeking
dgorsman
Re: AutoCAD 2016
« Reply #8 on: March 23, 2015, 07:07:10 PM »
Not just monthly, the Desktop Subscription/rental-model is available quarterly and yearly as well.  EMA and token users have other options.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
rkmcswain
Re: AutoCAD 2016
« Reply #9 on: March 24, 2015, 08:52:17 AM »
jumpy
Re: AutoCAD 2016
« Reply #10 on: March 25, 2015, 12:52:08 PM »
This just came through here at work too.
I'm still gnashing my teeth over the inability to snap to an intersection of a 600x600 square grid hatch without a lot of faff in v2015.
I'll peep at this one over my growing sense of having been done over.... again.
Acad 2018 / LT2018
DavidW
Re: AutoCAD 2016
« Reply #11 on: May 08, 2015, 10:46:13 AM »
My findings...
Since 2015 the solprof draws the normals of the arcs opposite.
There seems to be a serious precision issue caused regarding plugging in transformation matrices from vb6.
Function EIGEN_JK(ByRef M As Variant) As Variant
'**  Function computes the eigenvalues and eigenvectors for a real        **
'**  symmetric positive definite matrix using the "JK Method".  The       **
'**  first column of the return matrix contains the eigenvalues and       **
'**  the rest of the p+1 columns contain the eigenvectors.                **
'**  See:        **
'**  KAISER,H.F. (1972) "THE JK METHOD: A PROCEDURE FOR FINDING THE       **
'**  EIGENVALUES OF A REAL SYMMETRIC MATRIX", The Computer Journal,       **
'**  VOL.15, 271-273.                                                     **
Dim A() As Variant, Ematrix() As Double
Dim i As Long, j As Long, k As Long, iter As Long, p As Long
Dim den As Double, hold As Double, Sin_ As Double, num As Double
Dim Sin2 As Double, Cos2 As Double, Cos_ As Double, Test As Double
Dim Tan2 As Double, Cot2 As Double, tmp As Double
Const eps As Double = 1E-16
    On Error GoTo EndProc
    A = M
    p = UBound(A, 1)
    ReDim Ematrix(1 To p, 1 To p + 1)
    For iter = 1 To 15
        'Orthogonalize pairs of columns in upper off diag
        For j = 1 To p - 1
            For k = j + 1 To p
                den = 0#
                num = 0#
                'Perform single plane rotation
                For i = 1 To p
                    num = num + 2 * A(i, j) * A(i, k)   ': numerator eq. 11
                    den = den + (A(i, j) + A(i, k)) * _
                        (A(i, j) - A(i, k))             ': denominator eq. 11
                Next i
                'Skip rotation if aij is zero and correct ordering
                If Abs(num) < eps And den >= 0 Then Exit For
                'Perform Rotation
                If Abs(num) <= Abs(den) Then
                    Tan2 = Abs(num) / Abs(den)          ': eq. 11
                    Cos2 = 1 / Sqr(1 + Tan2 * Tan2)     ': eq. 12
                    Sin2 = Tan2 * Cos2                  ': eq. 13
                Else
                    Cot2 = Abs(den) / Abs(num)          ': eq. 16
                    Sin2 = 1 / Sqr(1 + Cot2 * Cot2)     ': eq. 17
                    Cos2 = Cot2 * Sin2                  ': eq. 18
                End If
                Cos_ = Sqr((1 + Cos2) / 2)              ': eq. 14/19
                Sin_ = Sin2 / (2 * Cos_)                ': eq. 15/20
                If den < 0 Then
                    tmp = Cos_
                    Cos_ = Sin_                         ': table 21
                    Sin_ = tmp
                End If
                Sin_ = Sgn(num) * Sin_                  ': sign table 21
                'Rotate
                For i = 1 To p
                    tmp = A(i, j)
                    A(i, j) = tmp * Cos_ + A(i, k) * Sin_
                    A(i, k) = -tmp * Sin_ + A(i, k) * Cos_
                Next i
            Next k
        Next j
        'Test for convergence
        Test = Application.SumSq(A)
        If Abs(Test - hold) < eps And iter > 5 Then Exit For
        hold = Test
    Next iter
    If iter = 16 Then MsgBox "JK Iteration has not converged."
    'Compute eigenvalues/eigenvectors
    For j = 1 To p
        For k = 1 To p
            Ematrix(j, 1) = Ematrix(j, 1) + A(k, j) ^ 2
        Next k
        Ematrix(j, 1) = Sqr(Ematrix(j, 1))
        'Normalize eigenvectors
        For i = 1 To p
            If Ematrix(j, 1) <= 0 Then
                Ematrix(i, j + 1) = 0
            Else
                Ematrix(i, j + 1) = A(i, j) / Ematrix(j, 1)
            End If
        Next i
    Next j
    EIGEN_JK = Ematrix
    Exit Function
EndProc:
    MsgBox prompt:="Error in function EIGEN_JK!" & vbCr & vbCr & _
        "Error: " & Err.Description & ".", Buttons:=48, _
        Title:="Run time error!"
End Function
This may work to fix them. I have not had success yet.
Other than that, nothing but a waste of time.
ps. Nice to see you all again. :)
Re: AutoCAD 2016
« Reply #12 on: January 06, 2016, 09:33:52 AM »
Now that 2017 is just around the corner we finally get 2016!
Like this.
Re: AutoCAD 2016
« Reply #13 on: January 06, 2016, 09:34:45 AM »
What controls the alphabetical order of layer names these day?
rkmcswain
Re: AutoCAD 2016
« Reply #14 on: January 06, 2016, 09:35:50 AM »
MAXSORT.
