Author Topic: Closed: Test yourself (for fun). Round 3. The winner is NICK_VNV  (Read 1681 times)
divtiply
« on: December 23, 2014, 03:20:30 PM »
Recognize the name of function that may be defined as
(defun f (a b c)
  (cond ((null c) nil)
        ((equal (car c) b) (cons a (f a b (cdr c))))
        (t (cons (car c) (f a b (cdr c))))))
(This function is exists in current AutoCAD's Lisp)
« Last Edit: December 23, 2014, 03:56:08 PM by divtiply »
NICK_VNV
Re: Test yourself (for fun). Round 3.
« Reply #1 on: December 23, 2014, 03:53:22 PM »
subst ?
divtiply
« Reply #2 on: December 23, 2014, 03:55:45 PM »
Re: Closed: Test yourself (for fun). Round 3. The winner is NICK_VNV
« Reply #3 on: December 23, 2014, 07:09:13 PM »
Are these the actual implementation or a function that mimics them?
« Reply #4 on: December 23, 2014, 07:11:54 PM »
Mimic
