Code Red => .NET => Topic started by: Draftek on March 30, 2006, 09:19:45 AM
I'm creating a context menu for some objects. I used the Editor.SelectedLast() method as a selection set but this is not returning what I thought it should.
Does anyone know how to caputure the currently selected item?
I'm not sure about .NET, but the COM object model provides access to pre-selected objects via the PickfirstSelectionSet property of the Document object. Maybe that will help you get pointed in the right direction.
Thanks, Chuck.
I'll take a look at that. It sounds like just the thing...
Or Editor.SelectPrevious or Editor.SelectImplied :)
Thanks, I'll try out both.
