Author Topic: strange error when using vlax-invoke-method 'GetObjectIdString  (Read 8124 times)
nivuahc
Re: strange error when using vlax-invoke-method 'GetObjectIdString
« Reply #15 on: December 29, 2010, 09:48:09 AM »
Hang on a sec...
One of the tests on the 32bit system DID cause the mysterious error, but it wasn't the first one  :?
nivuahc
« Reply #16 on: December 29, 2010, 09:58:14 AM »
All of the following is on 64bit MEP 2011 using the same drawing/object that I used in the 32bit tests above
Test 1:
(vlax-invoke-method (vla-get-Utility (vla-get-ActiveDocument
(vlax-get-acad-object))) 'GetObjectIdString (vlax-ename->vla-object (car
(entsel))) [color=red]:vlax-false[/color])
32bit: "2130071024"
64bit: "8796083987552"
(entsel))) [color=red]:vlax-true[/color])
32bit: "7EF64DF0"
64bit: "000007FFFF762460"
Test 2:
(vlax-invoke (vla-get-Utility (vla-get-ActiveDocument
(vlax-get-acad-object))) 'GetObjectIDString (vlax-ename->vla-object (car
32bit: "7EF64DF0"
32bit: "7EF64DF0"
Test 3:
(entsel))) [color=red]acFalse[/color])
32bit: "2130071024"
(entsel))) [color=red]acTrue[/color])
32bit: "7EF64DF0"
nivuahc
« Reply #17 on: December 29, 2010, 10:04:21 AM »
Hang on a sec...
Alright this is nuts...
I tried the first test twice in different sessions of 32bit MEP with no error. Now when I test it, I get that error every time.
Vaidas
« Reply #18 on: April 26, 2012, 02:59:51 AM »
Thanks for pointing on doubts between 32/64 bit systems.
(mapcar 'chr '(107 105 116 111 120 46 99 111 109))
