Author Topic: strange error when using vlax-invoke-method 'GetObjectIdString  (Read 8122 times)
nivuahc
« on: December 28, 2010, 04:50:28 PM »
Okay, so I keep getting this strange error that pops up whenever I use the following
(vlax-invoke-method
(vla-get-Utility
(vla-get-ActiveDocument
(vlax-get-acad-object)
'GetObjectIdString
(vlax-ename->vla-object
(car
(entsel)
:vlax-false
When I close MEP (2011, 64bit, Windows 7) I have the attached screen-shot pop-up on my screen. Click the "OK" button and it pops up again. Click the "OK" button again and it's gone.
Is this something I'm doing wrong or is this just another example of MEP being fickle?
Re: strange error when using vlax-invoke-method 'GetObjectIdString
« Reply #1 on: December 28, 2010, 04:57:54 PM »
Do you get the same result using:
(vlax-invoke
  (vla-get-Utility
  'GetObjectIDString
  (vlax-ename->vla-object (car (entsel)))
  :vlax-false
nivuahc
« Reply #2 on: December 28, 2010, 05:57:12 PM »
Nope.
Weird. :?
ETA:
vlax-invoke-method result: "8796084415712"
vlax-invoke result: "000007FFFF7CACE0"
« Last Edit: December 28, 2010, 06:02:20 PM by nivuahc »
« Reply #3 on: December 28, 2010, 06:05:58 PM »
looks like one is hex, the other a long ; truly weird
« Reply #4 on: December 28, 2010, 06:55:49 PM »
Spot on my friend  :-)
_$ (rtos (LM:Hex->Dec "000007FFFF7CACE0") 2 0)
"8796084415712"
(defun LM:Hex->Dec ( h / l )
   (if (zerop (setq l (strlen h))) 0
         (* (expt 16. (1- l))
               (lambda ( a ) (- a (if (< a 58) 48 55))) (ascii h)
         (LM:Hex->Dec (substr h 2))
Any excuse to write code...
_$ (LM:Dec->Hex 8796084415712.)
"7FFFF7CACE0"
(defun LM:Dec->Hex ( d )
      (  (< d 10)
         (chr (fix (+ d 48)))
      (  (< d 17)
         (chr (fix (+ d 55)))
      (  (strcat (LM:Dec->Hex (/ d 16)) (LM:Dec->Hex (rem d 16)))
« Last Edit: December 28, 2010, 07:02:15 PM by Lee Mac »
m4rdy
« Reply #5 on: December 29, 2010, 01:46:17 AM »
Having read your post for all of about 5 seconds, try switching
(vlax-invoke-method) to just (vlax-invoke) and try switching methods/properties
from strings to quoted symbols, eg. 'ElevationAt (that's a Tony T
recommendation). ActiveX within AECC is a little touchy so you sometimes have
to revert to the (vla-xxx) syntax. Localizing variables helps a lot too.
Let us know how you make out.
John Uhden, Cadlantic/formerly CADvantage
http://www.cadlantic.com
Sea Girt, NJ
http://forums.autodesk.com/t5/AutoCAD-Land-Desktop/odd-crashes-when-using-Land-Object-model-in-lisp/m-p/626525/highlight/true#M5393
Autocad 2007, Windows XP
gile
  • Marseille, France
« Reply #6 on: December 29, 2010, 03:27:45 AM »
Using vlax-invoke-method (or vla-GetObjectIdString) the returned value type depends on the last argument:
(vlax-invoke-method *Util* 'GetObjectIdString   obj :vlax-false) returns the result as a long.
(vlax-invoke-method *Util* 'GetObjectIdString   obj :vlax-true) returns the result as an hexa.
nivuahc
« Reply #7 on: December 29, 2010, 07:48:50 AM »
Which is funny considering the following:  :?
Command: (vlax-invoke
(_>   (vla-get-Utility
((_>     (vla-get-ActiveDocument
(((_>       (vlax-get-acad-object)
(((_>     )
((_>   )
(_>   'GetObjectIDString
(_>   (vlax-ename->vla-object (car (entsel)))
(_>   :vlax-true
(_> )
Select object: "000007FFFF7CAC00"
(((_>     )
((_>   )
(_>   :vlax-false
(_> )
« Reply #8 on: December 29, 2010, 07:57:59 AM »
Try:
(vlax-invoke
  (vla-get-Utility
  'GetObjectIDString
  acfalse
(vlax-invoke
  (vla-get-Utility
  'GetObjectIDString
  actrue
nivuahc
« Reply #9 on: December 29, 2010, 08:02:47 AM »
Hah!  :-D
(((_>     )
((_>   )
(_>   acfalse
(_> )
Select object: "8796084415488"
(((_>     )
((_>   )
(_>   actrue
(_> )
nivuahc
« Reply #10 on: December 29, 2010, 08:05:50 AM »
Also, no more error on exit.
I wonder what the heck that was all about...  :roll:
Thanks, Lee!
« Reply #11 on: December 29, 2010, 08:09:21 AM »
Thanks, Lee!
Beats me! Glad we got it sorted though  :-)
« Reply #12 on: December 29, 2010, 08:51:46 AM »
I can't test here at the moment, but do you get the same result on 32 bit and 64 bit machines.
I recall there was an issue with ObjectID extraction for fields with 32 bit and 64 bit machines.
nivuahc
« Reply #13 on: December 29, 2010, 09:41:34 AM »
All of the following is on 32bit MEP 2011
Test 1:
Command: (vlax-invoke-method (vla-get-Utility (vla-get-ActiveDocument
(vlax-get-acad-object))) 'GetObjectIdString (vlax-ename->vla-object (car
(entsel))) [color=red]:vlax-false[/color])
Select object: "2130071024"
(entsel))) [color=red]:vlax-true[/color])
Select object: "7EF64DF0"
FYI: No error on exit
Test 2:
Command: (vlax-invoke (vla-get-Utility (vla-get-ActiveDocument
(vlax-get-acad-object))) 'GetObjectIDString (vlax-ename->vla-object (car
Test 3:
(entsel))) [color=red]acFalse[/color])
(entsel))) [color=red]acTrue[/color])
nivuahc
« Reply #14 on: December 29, 2010, 09:45:47 AM »
All of the following is on 64bit MEP 2011 (not the exact same object, I'm running both systems on separate machines with a random piece of conduit drawn in space on each)
Test 1:
FYI: Mysterious error on exit
Test 2:
Test 3:
