Author Topic: possible to copy a dwg to another directory as a saved down version in lsp?  (Read 5228 times)
irneb
AFAIK, the 'version' parameter of the 'SaveAs' method doesn't work with ObjectDBX
That's very sad!  :'( ... Not unexpected though  :pissed: Typical ADesk bug ... it's probably been like that since 2000.
So if you want to batch convert DWGs you can only do so through scripts or using Net/ARX? Or is there similar bugs there as well?
its overkill for just 1 dwg
Why? I've got a script which DWF & PDF & eTransmits the current DWG to a zip file - ready for transmittal to consultants, clients, contractors, etc. All in a one-click button. It uses minimal lisping inside - just to get the correct filename sorted out from the title block's DWG# & Revision Code.
If it's just 1 DWG "ever" ... then why'd you even post here? I'm sure doing this save manually would have taken less time than to open your browser.  ;)
