Author Topic: Error handler help needed  (Read 5409 times)
Jeff_M
  • C3D user & customizer
Re: Error handler help needed
« Reply #15 on: August 10, 2006, 01:04:09 PM »
'kay,managed about 2 minutes on this so bear with me. Consider the implications of this little demo (no time to spell it out) --
Funny, it took less than 2 minutes for this to make my head hurt... :| I'll have to look this over to decipher it when I don't have real work to accomplish.....thanks Michael, it will give me something to do while my wife is driving on our trip to Oregon tomorrow.
« Reply #16 on: August 11, 2006, 01:04:43 PM »
Quick bash, may have errors ...
(defun c:Demo ( / _SetVars _Initializer _Terminator *error* _Main )
    (defun _SetVars ( lst )
        (mapcar
           '(lambda ( name value )
                (list
                    name
                    (getvar name)
                    value
                    (null
                        (vl-catch-all-error-p
                            (vl-catch-all-apply
                               '(lambda ( ) (setvar name value))
            (mapcar 'car lst)
            (mapcar 'cadr lst)
    (defun _Initializer ( document / undoIsEnabled oldSysVars )
        ;;  variable *debug* is a lexical global
        (if *debug* (princ "Entering Initializer ... "))
            (   (setq undoIsEnabled (< 0 (getvar "undoctl")))
                (while (eq 8 (logand 8 (getvar "undoctl")))
                    (vla-endundomark document)
                (vla-startundomark document)
        (setq oldSysVars
            (_SetVars
                    ("cmdecho"   0)
                    ("regenmode" 1)
                    ("attreq"    0)
                    ;;  yada
            (   *debug*
                (if undoIsEnabled (princ "<Undo Started> ... "))
                (princ "Exiting Initializer\n")
        ;;  return to caller
        (list
            (list 'document document)
            (list 'undoIsEnabled undoIsEnabled)
            (list 'oldSysVars oldSysVars)
    (defun _Terminator ( data / document undoIsEnabled oldSysVars )
        (if *debug* (princ "Entering Terminator ... "))
        (foreach arg '(document undoIsEnabled oldSysVars)
            (set arg (cadr (assoc arg data)))
        (if (and undoIsEnabled document) (vla-endundomark document))
        (if oldSysVars (_SetVars oldSysVars))
            (   *debug*
                (if (and undoIsEnabled document) (princ "<Undo Ended> ... "))
                (princ "Exiting Terminator\n")
    (defun *error* ( msg )
        (princ "*Abnormal program termination*\n")
        (if *debug* (vl-bt))
        ;;  variable terminatorData is a lexical global
        (_Terminator terminatorData)
    (defun _Main ( / terminatorData *debug* )
        (initget "Yes No")
        (if (eq "Yes" (getkword "Enable debug <verbose> mode? <No>: "))
            (setq *debug* t)
        (setq terminatorData
            (_Initializer
                (vla-get-activedocument
                    (vlax-get-acad-object)
        (initget "Yes No")
        (if (/= "No" (getkword "Do you want to crash me? <Yes>: "))
            (/ 1 0) ;; divide by zero error
        (princ "*Normal program termination*\n")
    (_Main)
DEMO [Enter]
Enable debug <verbose> mode? <No>: No
Do you want to crash me? <Yes>: No
DEMO [Enter]
Do you want to crash me? <Yes>: Yes
DEMO [Enter]
Enable debug <verbose> mode? <No>: Yes
Entering Initializer ... <Undo Started> ... Exiting Initializer
Entering Terminator ... <Undo Ended> ... Exiting Terminator
DEMO [Enter]
Backtrace:
[0.52] (VL-BT)
[1.48] (*ERROR* "divide by zero")
[2.43] (_call-err-hook #<SUBR @0cfd7654 *ERROR*> "divide by zero")
[3.37] (sys-error "divide by zero") :ERROR-BREAK.32 nil
[4.29] (/ 1 0)
[5.23] (_MAIN)
[6.19] (C:DEMO)
[7.15] (#<SUBR @0cfd7dac -rts_top->)
[8.12] (#<SUBR @0d0f2334 veval-str-body> "(C:DEMO)" T #<FILE internal>) ...
« Reply #17 on: August 11, 2006, 03:00:31 PM »
I've changed my mind about the setvars function, though I'll leave existing posts as is.
I think error trapping the individual setvar calls is a bad idea. I started to think about that approach as applies to my "real world" programming and I could not think of a single instance where I would want to mask a setvar error, that is, prevent a program from crashing. The simple reason being (for me) that a failed setvar call represents a design flaw in my program (either the variable name is wrong or the candidate value is invalid) so I'd actually want it to trash the program (so I could code it proper). As a result I would alter the setvars function to act accordingly --
(defun setvars ( lst )
    (mapcar
       '(lambda ( var val ) (list var (getvar var) (setvar var val)))
        (mapcar 'car lst)
        (mapcar 'cadr lst)
Argument lst is (still) of the form '(("var" val)("var" val)), for example '(("cmdecho" 0)("regenmode" 1)).
The result is of the form form '(("var" oldval newval), for example '(("cmdecho" 1 0)("regenmode" 0 1)) so it can still be passed to the setvars function later, say at the end of program execution.
I realize this thread has become a ghost town <not sure how I killed it, tmi?> and I'm talking to myself but that's ok, point is still valid.
« Reply #18 on: August 11, 2006, 03:07:22 PM »
I'm still reading it.  I have just devoted more time to 'try' and learn C#, so I'm not posting as much when I see others have taken, or are going to take, care of someone.  I was just watching to see where you were going, and I was hoping it was here, as that is what I think is the best way.
« Reply #19 on: August 12, 2006, 11:17:18 AM »
Thanks Tim, appreciated (on both counts).
PS: TMI meant "too much info", not a typo for Tim (in the remote chance that's the way you interpretted it).
