Code Red => AutoLISP (Vanilla / Visual) => Topic started by: jtoverka on February 24, 2020, 10:41:30 AM
Hello all,
How do I use sssetfirst within the callback function for :vlr-pickfirstmodified within the vlr-miscellaneous-reactor in a way that doesn't wipeout my selection set. This function will call trigger the reactor again, which I am able to bypass by checking a global variable I set before using sssetfirst. However when sssetfirst is complete and when the routine ends, it calls itself back but with an empty ssgetfirst and wipes everything out.
Everytime I select something, it wipes out the selection set and I am unable to select objects. :x
Turns out I was using sssetfirst incorrectly
(sssetfirst gripset [pickset])
I have it working now.
