Author Topic: Execute Method from String Name.  (Read 6489 times)
It's Alive!
  • Retired
  • AKA Daniel
Re: Execute Method from String Name.
« Reply #15 on: January 15, 2008, 11:17:32 PM »
Nice work Dave !!
MickD
« Reply #16 on: January 15, 2008, 11:20:13 PM »
Dictionary, map/hashtable,... whatever :D
Nice one Daniel.
- John Carmack
- J.R.R. Tolkien
Bryco
« Reply #17 on: January 16, 2008, 12:00:16 AM »
This situation comes into play with a menu,
In vba I had to make a sub for every menu item and when you are dealing with hardware there may be 80 subs that end up calling another function, however I could never figure out how to call a function passing it a string from a menu.
Perhaps the answers in this thread will work for this as well.
« Reply #18 on: January 16, 2008, 05:16:14 AM »
Thanks fellas .. that's heaps for me to play with .. when I get some time to spare.
your blood is worth bottling !
