Author Topic: Problem with (command "open") (must be Monday)  (Read 3819 times)
Dommy2Hotty
« on: June 13, 2005, 12:09:09 PM »
Just tested my new menu out, works great.  Loaded it on a ACAD2004 machine, and it flops.  Here are a bunch of different attempts:
[Basement]^C^C^C^P_open;"C:/Rockford Building Maintanence/Basement.dwg";
**BRINGS UP FILEDIALOG BOX, I CLICK CANCEL**
Unknown command ""C:/ROCKFORD BUILDING MAINTANENCE/SECOND FLOOR.DWG"".  Press
F1 for help.
Command: (command "open" "C:/Rockford Building Maintanence/Basement.dwg")
open
Command: C:/Rockford Building Maintanence/Basement.dwg Unknown command
"C:/ROCKFORD BUILDING MAINTANENCE/BASEMENT.DWG".  Press F1 for help.
Command: nil
[Basement]^C^C^C(setq fdia (getvar "filedia"));(setvar "filedia" 0);open;"C:/Rockford Building Maintanence/Basement.dwg");(setvar "filedia" 0);
Command: (setq fdia (getvar "filedia"))
1
Command: (setvar "filedia" 0)
0
Command: open
Enter name of drawing to open <.>: ***I HAVE TO HIT ESC***
Command: "C:/Rockford Building Maintanence/Basement.dwg")
Unknown command ""C:/ROCKFORD BUILDING MAINTANENCE/BASEMENT.DWG")".  Press F1
for help.
0
[Basement]^C^C^C(setq fdia (getvar "filedia"));(setvar "filedia" 0);(setq file "C:/Rockford Building Maintanence/Basement.dwg");(command "open" file);(setvar "filedia" 0);
0
0
Command: (setq file "C:/Rockford Building Maintanence/Basement.dwg")
Command: (command "open" file)
open
Command: nil
0
[Basement]^C^C^C(setq fdia (getvar "filedia"));(setvar "filedia" 0);(setq file "C:/Rockford Building Maintanence/Basement.dwg");open;!file;(setvar "filedia" 0);
0
0
Command: open
Command: !file
0
David Hall
  • Automatic Duh Generator
« Reply #1 on: June 13, 2005, 12:48:56 PM »
What did it work on before 2004?
Dommy2Hotty
« Reply #2 on: June 13, 2005, 12:54:53 PM »
Quote from: CmdrDuh
I have 2005 on my machine...sorry...shoulda mentioned that...my sig is kinda small
David Hall
« Reply #3 on: June 13, 2005, 01:46:15 PM »
Actually I should open my eyes.
OK , so what is different about 2005 than 4?  do you have SDI = 0 on both? Any other custom settings you use that the average user wouldn't have?
Dommy2Hotty
« Reply #4 on: June 13, 2005, 01:59:51 PM »
I've got custom settings up the butt on mine, but the 2004 system is raw AutoCAD.  Thing is, I'm not using anything custom in my macro.  Just your standard open command.
David Hall
« Reply #5 on: June 13, 2005, 02:01:03 PM »
yes, but there could be a sysver that neither of us is thinking of that is preventing your "plain" macro from working
« Reply #6 on: June 13, 2005, 02:50:39 PM »
Have you tried
[Basement]^C^C^C^P_open;"C:\\Rockford Building Maintanence\\Basement.dwg";
Another Option
;;; SOPEN.LSP
;;; Open command that works for all cases
;;; Works for SDI=0 or SDI=1
;;; By Jimmy Bergmark
;;; Copyright (C) 1997-2003 JTB World, All Rights Reserved
;;; Website: www.jtbworld.com
;;; E-mail: info@jtbworld.com
;;; 1999-09-12 - First release
;;; 2002-05-14 - Bug fixed
;;; Written for AutoCAD 2000+
;;; Ex: (sopen "c:\\drawing1.dwg")
;;; Note that QAFLAGS might not be restored to 0 so you might want to add (setvar "qaflags" 0) to acaddoc.lsp or any other startup lisp.
;;; opens and activates a file as Read-Only
(defun openRO (fna)
  (vla-activate (vla-open (vla-get-documents (vlax-get-acad-object)) fna :VLAX-TRUE))
(defun sopen (fna / n)
  (if (= 0 (getvar "SDI"))
    (vla-activate (vla-open (vla-get-documents (vlax-get-acad-object)) fna))
      (if (not (equal 2 (logand 2 (getvar "qaflags"))))
        (setvar "qaflags" (+ (getvar "qaflags") 2))
      (if (not (equal 4 (logand 4 (getvar "qaflags"))))
       (setvar "qaflags" (+ (getvar "qaflags") 4))
      (command "_.open")
      (if (not (equal 0 (getvar "dbmod")))
        (command "_y")
      (command fna)
      (setq n 0)
      (while (and (< n 4)
                  (wcmatch (getvar "cmdnames") "*OPEN*")
          (T
            (command "")
        (setq n (+ n 1))
Dommy2Hotty
« Reply #7 on: June 13, 2005, 04:34:37 PM »
Quote from: CmdrDuh
Yeah...there is...SDI
Set it to "1" on the 2004 machine and it worked fine.  SO!  Now that I know it's the SDI mode that's causing this, does anyone know a work around for that?  I'm developing this menu system for client, and I would like it to be able to work with both SDI on and off.
