With exposed CurrentPalette property, if you need to access the controls inside the Palette, such as a TextBox, you simply cast it into corresponding UserControl, and then whatever you exposed from the UserControl, you can access it, you have full control.
public interface IMyPalette
Dictionary<string, string> TextBoxValues { set; get; }
string PaletteName { set; get; }
public partial class PaletteA : UserControl, IMyPalette
private string _paletteName = "";
public PaletteA()
InitializeComponent();
public string PaletteName
set { _paletteName=value;}
get { return _paletteName; }
public Dictionary<string, string> TextBoxValues
get
//Assume you want to expose a set of text boxes on the UserControl
Dictionary<string, string> dic = new Dictionary<string, string>();
foreach (Control c in this.Controls)
TextBox txt = c as TextBox;
if (txt!=null)
dic.Add(txt.Name, txt.Text);
return dic;
set
if (txt != null)
if (value.ContainsKey(txt.Name))
txt.Text = value[txt.Name];
public partial class PaletteB : UserControl, IMyPalette
private string _paletteName="";
public PaletteB()
set { _paletteName = value; }
get
if (txt!=null)
return dic;
set
if (txt != null)
public class MyPaletteSet : Autodesk.AutoCAD.Windows.PaletteSet
private string _currentPaletteName = null;
private Dictionary<string, IMyPalette> _palettes = new Dictionary<string, IMyPalette>();
public MyPaletteSet()
:base("MyPs",new Guid("4F17DF6C-99AE-44D8-BBB1-08ED1E873000"))
this.Style = PaletteSetStyles.ShowAutoHideButton |
PaletteSetStyles.ShowCloseButton |
PaletteSetStyles.Snappable;
this.Opacity = 100;
this.Dock = DockSides.None;
this.DockEnabled = DockSides.None;
this.Size = new Size(500, 400);
this.MinimumSize = new Size(250, 200);
Initialize();
public string CurrentPaletteName
get { return _currentPaletteName; }
public IMyPalette CurrentPalette
get { return _palettes[_currentPaletteName]; }
public Dictionary<string, string> GetPaletteTextBoxes(string paletteName)
if (_palettes.ContainsKey(paletteName))
return _palettes[paletteName].TextBoxValues;
else
throw new KeyNotFoundException("No palette with name \"" + paletteName + "\" found.");
private void Initialize()
PaletteA a = new PaletteA();
a.PaletteName = "Pallete A";
this.Add(a.PaletteName, a);
_palettes.Add(a.PaletteName, a);
PaletteB b = new PaletteB();
b.PaletteName = "Palette B";
this.Add(b.PaletteName, b);
_palettes.Add(b.PaletteName,b);
this.PaletteActivated += MyPaletteSet_PaletteActivated;
this.Activate(0);
_currentPaletteName = this[0].Name;
void MyPaletteSet_PaletteActivated(object sender, PaletteActivatedEventArgs e)
_currentPaletteName = e.Activated.Name;
public class MyCommands
private static MyPaletteSet _ps = null;
[CommandMethod("ShowPS", CommandFlags.Session)]
public static void RunMyCommand()
Document dwg = Application.DocumentManager.MdiActiveDocument;
Editor ed = dwg.Editor;
if (_ps==null)
_ps = new MyPaletteSet();
_ps.Visible = true;
[CommandMethod("CurrentPt")]
public static void ShowCurrentPallete()
if (_ps!=null && _ps.Visible)
Application.ShowAlertDialog("Current palette is \"" + _ps.CurrentPaletteName + "\".");
//Get existing text boxes' value
Dictionary<string, string> dic = _ps.GetPaletteTextBoxes(_ps.CurrentPaletteName);
ShowPaletteTextBoxValues(dic);
//Set text boxes' value
SetPaletteTextBoxValues(dic, _ps.CurrentPaletteName);
//Show changed values
else
Application.ShowAlertDialog("MyPaletteSet is not visible");
private static void ShowPaletteTextBoxValues(Dictionary<string,string> dic)
StringBuilder values = new StringBuilder();
foreach (KeyValuePair<string,string> item in dic)
values.Append(item.Key + "=" + item.Value + "\n");
Application.ShowAlertDialog(values.ToString());
private static void SetPaletteTextBoxValues(Dictionary<string,string> dic, string paletteName)
Dictionary<string, string> newDic = new Dictionary<string, string>();
foreach (KeyValuePair<string, string> item in dic)
switch(item.Key.ToUpper())
case "TEXTBOX1":
newDic.Add(item.Key, "XXXX");
break;
case "TEXTBOX2":
newDic.Add(item.Key, "YYYY");
break;
case "TEXTBOX3":
newDic.Add(item.Key, "ZZZZ");
break;
_ps.CurrentPalette.TextBoxValues = newDic;
sending in different catalog information in the constructor...
...streamline the process of going thru the mvpartadd dialogs.
Creating a Mvpart should not have know or worry about what palette is current or any UI element just creating it and exposes state if needed.
