Author Topic: How do I explode a block using a script?  (Read 8358 times)
Luke
« on: January 10, 2008, 11:27:22 AM »
I thought I already posted this but had some errors...
Anyhow, how do you insert a drawing using a script and explode it through the script also.  I got the insert part handled but can not figure out how to explode.
The drawing appears empty but actually has my dimension styles embedded in it.
David Hall
  • Automatic Duh Generator
Re: How do I explode a block using a script?
« Reply #1 on: January 10, 2008, 11:29:31 AM »
explode;last;
Luke
« Reply #2 on: January 10, 2008, 11:37:08 AM »
That's what I thought but try it once.
It's like because the drawing I'm trying to insert as a block is "empty" the command last is not recognized...
David Hall
« Reply #3 on: January 10, 2008, 11:44:53 AM »
Maybe place a "point" at 0,0 in your insert so it will explode
Luke
« Reply #4 on: January 10, 2008, 11:49:35 AM »
Still doesn't find it
« Reply #5 on: January 10, 2008, 11:52:37 AM »
To use the 'last' option, the object has to be on the screen.  If it's not, then you can use the lisp function '(entlast)'.
« Reply #6 on: January 10, 2008, 11:57:49 AM »
If I recall you need to include and asterisks before the file name and it inserts exploded. use the -insert command in your script.
Luke
« Reply #7 on: January 10, 2008, 11:59:36 AM »
The script I attached is just a small portion of a whole huge script that is doing a bunch of other things.  These are all aready in place and there are a bunch.
I pasted the '(entlast)' into the script after I added explode but it doesn't work.  Is there something additional I can do to the script to make it work?
;;;               THIS CODE INSERTS THE DIMENSION STYLE DRAWING                 ;;;
-insert
LCC_DIMSTYLES.dwg
0,0,0
1
1
0
explode
'(entlast)'
;..........................................................................FINISHED
« Reply #8 on: January 10, 2008, 12:01:05 PM »
Try (command "._explode" (entlast))....or MJ's solution.
Luke
« Reply #9 on: January 10, 2008, 12:10:43 PM »
If I use the * per mjfarrell  code needs to be...
-insert
*LCC_DIMSTYLES.dwg
0,0,0
[color=red]1[/color]
0
If I use the (command "._explode" (entlast)) per ronjonp code needs to be...
-insert
LCC_DIMSTYLES.dwg
0,0,0
[color=red]1
1[/color]
0
not quite sure why ACAD changes the prompts with the * input but it works.
Thanks!!  Greatly appreciated!
« Reply #10 on: January 10, 2008, 12:18:49 PM »
you can also keep everything on the same line like so: -insert LCC_DIMSTYLES.dwg 0,0,0 1 1 0
« Reply #11 on: January 10, 2008, 12:20:37 PM »
Acad acts funny if the block is not scaled the same in all directions.  I assume that is why you only need to enter one scale factor when you know the block is going to be exploded on insert.
David Hall
« Reply #12 on: January 10, 2008, 12:21:58 PM »
changing the thought process a little, I think I did this a while back, and when Acad asked for insert point, I hit ESC with a (command) to cancel out.  Does this ring a bell?
David Hall
« Reply #13 on: January 10, 2008, 12:23:12 PM »
I tested from the command line and it works
« Reply #14 on: January 10, 2008, 12:26:25 PM »
This is a technique to insert the block into the drawings block collection, but not actually insert it into the drawing space.
