Author Topic: Too few Arguments (VL-REMOVE-IF)  (Read 8420 times)
« on: June 04, 2009, 06:56:08 AM »
I cannot see why I am having trouble with this code:
(setq uniq
        (vl-remove-if
          (function
            (lambda (x y)
              (= (car x) (car y)))) '((1 . 2) (1 . 3) (2 . 4))))
I am trying to remove elements for which the first element is equal, hence the return of the above would be ((2 . 4)).
But I am receiving the error: too few arguments.
Any help is appreciated, thanks.
Lee
Re: Too few Arguments (VL-REMOVE-IF)
« Reply #1 on: June 04, 2009, 08:03:55 AM »
Try this:
(setq uniq nil y nil)
(setq uniq
        (vl-remove-if
          (function
            (lambda (x)
              (cond ((null y) (setq y x))
                    ((= (car x) (car y)))))) '((1 . 2) (1 . 3) (2 . 4))))
« Reply #2 on: June 04, 2009, 08:10:50 AM »
That doesn't work. Back to the drawing board! :oops:
« Reply #3 on: June 04, 2009, 08:17:09 AM »
Thanks for your suggestion CAB - your time on this is appreciated  :angel:
I can't see why this is proving such a problem - I thought it would be a no brainer when I wrote it into my code, only to find an error  :-(
« Reply #4 on: June 04, 2009, 08:18:35 AM »
This returns a unique list, but doesn't eliminate all that have duplicates.
(setq uniq nil)
(vl-remove-if
  (function
    (lambda (x)
      (cond ((null uniq) (setq uniq (list x)))
            ((= (car x) (caar uniq)))
            ((setq uniq (cons x uniq)))
  '( (1 . 2) (1 . 3)(2 . 4))
« Reply #5 on: June 04, 2009, 08:30:14 AM »
not pretty, but seems to work
(defun RemoveDupeKeys (MyList / key keylist resultlist)
;;CodeHimBelongs kdub
    (setq resultList MyList
          keyList    (mapcar 'car MyList)
    (while (setq key     (car keyList)
                 keylist (cdr keyList)
        (if (member key keylist)
            (setq resultList
                     (vl-remove-if
                         (function (lambda (x) (= key (car x))))
                         resultList
    resultList
/// kdub
(RemoveDupeKeys '((1 . 2) (1 . 3) (2 . 4) (3 . 4) (4 . 4) (3 . 4) ))
==> ((2 . 4) (4 . 4))
« Reply #6 on: June 04, 2009, 08:43:11 AM »
Same here. (not pretty)
(defun Remove_Car_doups (lst / x result)
  (while (setq x (car lst))
    (setq lst (cdr lst))
    (if (not (vl-some '(lambda (y) (= (car x) (car y))) lst))
      (cond ((null result)(setq result (list x)))
            ((setq result (cons x result))))
    (setq lst (vl-remove-if '(lambda (y) (= (car x) (car y))) lst))
  result
« Reply #7 on: June 04, 2009, 08:50:52 AM »
Many thanks for your solutions guys - although messy by stepping through the list, they do get the job done  :-)
I still can't believe how much coding is needed for a task like this - am I right to believe that vl-remove-if can only take a predicate function with one argument?
Lee
« Reply #8 on: June 04, 2009, 08:59:11 AM »
The lambda iterates the list('s) passed in and deals with each item sequentially ..
if you check the help ...
predicate-function
The test function. This can be any function that accepts a single argument and returns T for any user-specified condition. The predicate-function value can take one of the following forms:
A symbol (function name)
'(LAMBDA (A1 A2) ...)
(FUNCTION (LAMBDA (A1 A2) ...))
« Last Edit: June 04, 2009, 09:03:20 AM by Kerry Brown »
« Reply #9 on: June 04, 2009, 09:30:25 AM »
Ah gotcha. Thanks Kerry   8-)
gile
  • Marseille, France
« Reply #10 on: June 04, 2009, 01:33:04 PM »
A recursive way
(defun uniq (l)
  (if l
    (if (assoc (caar l) (cdr l))
      (uniq (vl-remove-if '(lambda (x) (= (car x) (caar l))) l))
      (cons (car l) (uniq (cdr l)))
EDIT : replace the 'vl-some' statement by an 'assoc' one
« Last Edit: June 04, 2009, 03:18:43 PM by gile »
« Reply #11 on: June 04, 2009, 02:02:04 PM »
Very Nice Gile  8-)
I love these Recursive solutions  :-)
« Reply #12 on: June 04, 2009, 02:07:12 PM »
Okay I couldn't resist the challenge.
(setq testList '((1 . 2) (1 . 3) (2 . 4)))
(vl-remove-if
    (function
        (lambda ( x / tempList )
            (or
                (and
                    (setq tempList (assoc (car x) testList))
                    (not (equal tempList x))
                (assoc (car x) (cdr (member x testList)))
    testList
Returned: ((2 . 4))
« Reply #13 on: June 04, 2009, 02:08:57 PM »
[color=green];;  To me problems like this tend to want to distill down to
;;  core problems. Seems to me there are two problems: (1) Find
;;  duplicated keys and (2) remove pairs by specifying the keys.
;;  As such, I tend to form libraries with discrete functions
;;  that perform only one task. Solutions are penned putting
;;  together said singularly minded functions ...[/color]
(defun _FindDuplicatedKeys ( pair_lists / n result )
    (while pair_lists
            (and
                (assoc (setq key (caar pair_lists)) (setq pair_lists (cdr pair_lists)))
                (null (member key result))
            (setq result (cons key result))
    result
[color=green];;  The following is overkill, but in the interests of a
;;  somewhat clean, easy to understand, self documenting
;;  solution ...[/color]
(defun _RemoveByKeys ( pair_lists keys )
    (vl-remove-if
       '(lambda (pair) (member (car pair) keys))
        pair_lists
[color=green];;  A possible solution ...[/color]
(setq pair_lists '((1 . 2) (1 . 3) (2 . 4)))
(_RemoveByKeys
    pair_lists
    (_FindDuplicatedKeys pair_lists)
=> ((2 . 4))
Overkill? Perhaps.
Verbose? Yup.
Re-usable? Me thinks so.
Cheers.
« Reply #14 on: June 04, 2009, 02:20:09 PM »
MP many thanks for this post -
I always learn such a lot from your well documented functions - great work mate.
Cheers,
Lee
