Author Topic: Auto update field  (Read 3532 times)
Matersammichman
Auto update field
« on: April 14, 2008, 01:09:46 PM »
I have a field inside an attribute.
Anyone have VBA code to auto-update it after editing without my having to constantly type in regen?
(2007)
Guest
Re: Auto update field
« Reply #1 on: April 14, 2008, 01:12:49 PM »
(2007)
You mean something like ThisDrawing.RegenAll ??!?
Matersammichman
« Reply #2 on: April 14, 2008, 01:16:34 PM »
Yes, but what Event do I use to get it to auto-run after editing the attribute/field?
« Reply #3 on: April 14, 2008, 01:50:32 PM »
it can be done with an object reactor to send Object.Update to the blockreference and/or attribute and/or field
Matersammichman
« Reply #4 on: April 14, 2008, 02:09:32 PM »
Uhhh...say again Houston?
deegeecees
« Reply #5 on: April 14, 2008, 03:06:25 PM »
Its a start...
Private Sub AcadDocument_EndCommand(ByVal CommandName As String)
 If CommandName = "EATTEDIT"
 End If
« Reply #6 on: April 14, 2008, 03:15:51 PM »
you could try this:
Private Sub AcadDocument_ObjectModified(ByVal acadObject As Object)
    acadObject.UpDate
Matersammichman
« Reply #7 on: April 16, 2008, 09:57:54 AM »
I've tried numerous modifications.
None work without getting caught in an endless loop.
Guest
« Reply #8 on: April 16, 2008, 10:00:05 AM »
Can you post what you've got so far?
Matersammichman
« Reply #9 on: April 16, 2008, 10:22:21 AM »
Unfortunately, no.
When it doesn't work, I blow it away.
Suffice it to say they were the originals offered above, and derivations thereof.
« Reply #10 on: April 16, 2008, 10:38:36 AM »
Keep in mind that you cannot modify an object inside of the ObjectModified event, to do so would cause an infinite loop
