Author Topic: CapsLOCK on ?  (Read 4890 times)
CapsLOCK on ?
« Reply #30 on: August 12, 2005, 01:22:18 PM »
Quote from: Bob Wahr
Dim intP As Peeps
Dim strMe As Member
Set intP = TheSwamp.InterestedParties
strMe = TheSwamp.CurrentPost.MemberName
intP.Add(strMe)
Eek, too many errors.
If strMe is an object variable it needs to be set (data type Member is not an intrinsic type thus must be a UDC*; if it were a UDT the call would reference an element via dot delineation), so ...
Set strMe = TheSwamp.CurrentPost.MemberName
(even though it appears by inference to be a string type variable).
Also, you cannot invoke code like this:
intP.Add (strMe)
Either
intP.Add strMe
or
Call intP.Add (strMe)
However, since we want the addition of names to be persistant perhaps this would suffice --
With TheSwamp
    Call .Tutorials.Item("Tortoise/Subversion").InterestedParties.Add (.CurrentPost.MemberName)
End With
Forgive me, I'm such a geek I couldn't stop myself (ya I know, I'm a bstrd).
:oops: :oops: :oops:
* UDC = User Defined Class; UDT = User Defined Type
CapsLOCK on ?
« Reply #31 on: August 12, 2005, 02:20:09 PM »
...Stig, you do realize that you have competition for passing out headaches right?
  • Custom Title
CapsLOCK on ?
« Reply #32 on: August 12, 2005, 03:09:38 PM »
Bob Wahr
CapsLOCK on ?
« Reply #33 on: August 12, 2005, 03:44:59 PM »
Oh crap!
I've been geek served.
