Code Red => AutoLISP (Vanilla / Visual) => Topic started by: csgoh on July 12, 2006, 08:34:00 PM
Question 1.
I wrote this function a to thaw,on and unlock. However, whenever the layer is a current layer, it gives me an "Automation Error. Invalid layer". Any remedy to the problem is much appreciated.
;; wg:activate-layer
;; function to turn on, thaw and unlock if layers exist.
(defun WG:activate-layer (lan1 objLayers / layer)
(cond ((not (vl-catch-all-error-p (setq layer (vl-catch-all-apply 'vla-item (list objLayers lan1)))))
(vla-put-Freeze layer ':vlax-false)
(vla-put-Layeron layer ':vlax-true)
(vla-put-Lock layer ':vlax-false)
(princ (strcat "\nLayer " lan1 " on,thawed & unlocked ....")
) ;_WG:activate-layer
Question 2.
How do one convert a handle to a vla-object?
Thanks.
1. You cannot use the Freeze property on the ActiveLayer, rather you can query it but you cannot set it....even if it's to false. So just add a check to see if lan1 is current before setting that property.
2. (vla-handletoobject (vla-get-activedocument (vlax-get-acad-object)) handle)
