;++++++++++++ Make The Perforated False Pan +++++++++++++++++++++++++++;;;ARG -> Xwidth YDepth Inpoint(defun ppf_perf (x y i / xq xs xh xp yq ys yh yp bn)(entmake (list (cons 0 "BLOCK")(cons 2 "*U")(list 10 0 0 0)(cons 70 1)))(entmake (list (cons 0 "LINE")(cons 8 "3D")(cons 39 -1)(cons 10 (list 0 y 0))(cons 11 (list 0 0 0))))(entmake (list (cons 0 "LINE")(cons 8 "3D")(cons 39 -1)(cons 10 (list x y 0))(cons 11 (list 0 y 0))))(entmake (list (cons 0 "LINE")(cons 8 "3D")(cons 39 -1)(cons 10 (list x 0 0))(cons 11 (list x y 0))))(entmake (list (cons 0 "LINE")(cons 8 "3D")(cons 39 -1)(cons 10 (list 0 0 0))(cons 11 (list x 0 0))))(setq xq (fix (/ x 2)) xs (/ x xq) yq (fix (/ y 2)) ys (/ y yq) xh (* xs 0.5) yh (* ys 0.5))(setq xp (* xs 0.5) yp (* ys 0.5))(repeat xq (setq yp (* ys 0.5)) (repeat yq (entmake (list (cons 0 "3DFACE")(cons 8 "3D")(cons 10 (list (+ xp (- xh)) (+ yp 0) 0))(cons 11 (list (+ xp -0.70710678) (+ yp 0) 0))(cons 12 (list (+ xp 0) (+ yp 0.70710678) 0))(cons 13 (list (+ xp (- xh)) (+ yp (+ yh)) 0))(cons 70 13))) (entmake (list (cons 0 "3DFACE")(cons 8 "3D")(cons 10 (list (+ xp 0) (+ yp 0.70710678) 0))(cons 11 (list (+ xp (+ xh)) (+ yp (+ yh)) 0))(cons 12 (list (+ xp (- xh)) (+ yp (+ yh)) 0))(cons 13 (list (+ xp 0) (+ yp 0.70710678) 0))(cons 70 15))) (entmake (list (cons 0 "3DFACE")(cons 8 "3D")(cons 10 (list (+ xp -0.70710678) (+ yp 0) 0))(cons 11 (list (+ xp (- xh)) (+ yp (+ yh)) 0))(cons 12 (list (+ xp (- xh)) (+ yp (- yh)) 0))(cons 13 (list (+ xp -0.70710678) (+ yp 0) 0))(cons 70 15))) (entmake (list (cons 0 "3DFACE")(cons 8 "3D")(cons 10 (list (+ xp 0) (+ yp (- yh)) 0))(cons 11 (list (+ xp 0) (+ yp -0.70710678) 0))(cons 12 (list (+ xp -0.70710678) (+ yp 0) 0))(cons 13 (list (+ xp (- xh)) (+ yp (- yh)) 0))(cons 70 13))) (entmake (list (cons 0 "3DFACE")(cons 8 "3D")(cons 10 (list (+ xp 0) (+ yp -0.70710678) 0))(cons 11 (list (+ xp (- xh)) (+ yp (- yh)) 0))(cons 12 (list (+ xp (+ xh)) (+ yp (- yh)) 0))(cons 13 (list (+ xp 0) (+ yp -0.70710678) 0))(cons 70 15))) (entmake (list (cons 0 "3DFACE")(cons 8 "3D")(cons 10 (list (+ xp (+ xh)) (+ yp 0) 0))(cons 11 (list (+ xp 0.70710678) (+ yp 0) 0))(cons 12 (list (+ xp 0) (+ yp -0.70710678) 0))(cons 13 (list (+ xp (+ xh)) (+ yp (- yh)) 0))(cons 70 13))) (entmake (list (cons 0 "3DFACE")(cons 8 "3D")(cons 10 (list (+ xp 0.70710678) (+ yp 0) 0))(cons 11 (list (+ xp (+ xh)) (+ yp (- yh)) 0))(cons 12 (list (+ xp (+ xh)) (+ yp (+ yh)) 0))(cons 13 (list (+ xp 0.70710678) (+ yp 0) 0))(cons 70 15))) (entmake (list (cons 0 "3DFACE")(cons 8 "3D")(cons 10 (list (+ xp 0) (+ yp (+ yh)) 0))(cons 11 (list (+ xp 0) (+ yp 0.70710678) 0))(cons 12 (list (+ xp 0.70710678) (+ yp 0) 0))(cons 13 (list (+ xp (+ xh)) (+ yp (+ yh)) 0))(cons 70 13))); (entmake (list (cons 0 "3DFACE")(cons 8 "3D-BLACK")(cons 10 (list (+ xp 0) (+ yp -0.70710678) 0))(cons 11 (list (+ xp 0.70710678) (+ yp 0) 0))(cons 12 (list (+ xp 0) (+ yp 0.70710678) 0))(cons 13 (list (+ xp -0.70710678) (+ yp 0) 0))(cons 70 0))) (entmake (list (cons 0 "LINE")(cons 8 "2D")(cons 10 (list (+ xp 0) (+ yp -0.70710678) 0))(cons 11 (list (+ xp 0.70710678) (+ yp 0) 0)))) (entmake (list (cons 0 "LINE")(cons 8 "2D")(cons 10 (list (+ xp 0.70710678) (+ yp 0) 0))(cons 11 (list (+ xp 0) (+ yp 0.70710678) 0)))) (entmake (list (cons 0 "LINE")(cons 8 "2D")(cons 10 (list (+ xp 0) (+ yp 0.70710678) 0))(cons 11 (list (+ xp -0.70710678) (+ yp 0) 0)))) (entmake (list (cons 0 "LINE")(cons 8 "2D")(cons 10 (list (+ xp -0.70710678) (+ yp 0) 0))(cons 11 (list (+ xp 0) (+ yp -0.70710678) 0)))) (setq yp (+ yp ys))) (setq xp (+ xp xs)))(entmake (list (cons 0 "LINE")(cons 8 "1D")(cons 10 (list 0 y 0))(cons 11 (list 0 0 0))))(entmake (list (cons 0 "LINE")(cons 8 "1D")(cons 10 (list x y 0))(cons 11 (list 0 y 0))))(entmake (list (cons 0 "LINE")(cons 8 "1D")(cons 10 (list x 0 0))(cons 11 (list x y 0))))(entmake (list (cons 0 "LINE")(cons 8 "1D")(cons 10 (list 0 0 0))(cons 11 (list x 0 0))))(setq bn (entmake (list (cons 0 "ENDBLK")(cons 8 "0"))))(entmake (list (cons 0 "INSERT")(cons 2 bn)(cons 8 "0")(cons 10 i))));++++++++++++ Get The User Inputs +++++++++++++++++++++++++++++++++++++(defun c:perfpan (/ x y ip el) (initget 7) (setq x (getdist "\nX Width S-S: ")) (initget 7) (setq y (getdist "\nY Depth F-B: ")) (initget 1) (setq ip (getpoint "\nInsert Point: " )) (initget 6) (setq el (getdist (strcat "\nSurface Elevation <" (rtos (getvar "ELEVATION") 2 2)">: "))) (or el (setq el (getvar "ELEVATION"))) (ppf_perf x y (list (car ip) (cadr ip) el)) (prin1))
