Author Topic: Data list manipulation  (Read 5604 times)
noadea
« on: April 16, 2007, 05:49:21 AM »
Hi All,
I have a problem to manipulate the data list. Here are example of data in csv format:
1   1
2   -
3   -
4   -
5   4
6   5
7   6
8   -
9   7
10   8
11   -
12   -
13   10
From the data list, i suppose to draw line according to data by row. For better understanding, I attached the roughly drawing to describe my need. If refer to data square1 connect to circle1, square5 to circle4, square6 to circle5... But the problem here is the circles with "-" value in csv file. Example square2, square3 and square4 which connect to 3 different points between circle1 and circle4. How to get the  different points refer to the total of "-" at the time? (3 points between circle1 and circle4, 1 point between circle6 and circle7, 2 points between circle8 and circle10). Then the line should be drawn from square to point according to data in row. Thanks.
It's Alive!
  • Retired
  • AKA Daniel
Re: Data list manipulation
« Reply #1 on: April 16, 2007, 05:57:37 AM »
Got any code so we can see what you have so far?
noadea
« Reply #2 on: April 16, 2007, 06:54:21 AM »
Here I attached the code that I  have for this moment.
« Reply #3 on: April 16, 2007, 07:18:05 AM »
For thoses interestd, here is the original thread:
http://forums.augi.com/showthread.php?t=58847
noadea
« Reply #4 on: April 17, 2007, 03:06:28 AM »
This problem is outside of my programming level. I hope there are experts would help me solve this problem. Thank you.
« Reply #5 on: April 17, 2007, 05:45:00 AM »
Where is the datalist for a sampling of squares and circle locations ?
« Reply #6 on: April 17, 2007, 05:52:06 AM »
Is the connection pattern different each time ?
Do you have a sample csv file ?
Do you have a sample drawing file. ?
at least give us ALL the information.
How many of these are you doing. ?
Is it a school project ?
noadea
« Reply #7 on: April 17, 2007, 07:30:28 AM »
Here are sample of drawing and csv file.
« Last Edit: April 17, 2007, 07:31:58 AM by noadea »
« Reply #8 on: April 17, 2007, 07:32:38 AM »
Good questions Kerry, I hope we get the answers.
I had very little time yesterday & less time today. :(
But here is what I started with. An assumption about the data list from the cvs file.
Then several hoops to get the data in a usable form.
I was about to replace the nil values according to the specifications when time ran out.
So here is what I have so far. Maybe tomorrow will be better for me. :?
(defun c:test ()
  ;;  given output from CVS file
  (setq output '("5,23,27,24"      "5,22,-,-"        "5,21,-,-"
                 "5,20,-,-"        "5,19,29,19.5"    "5,18,30,17.75"
                 "5,17,30,16.5"    "5,16,-,-"        "5,15,30,15"
                 "5,14,30,13"      "5,13,-,-"        "5,12,-,-"
                 "5,11,30,10"
  ;;  parser by CAB single character delim
  (defun sparser (str delim / ptr lst)
    (while (setq ptr (vl-string-search delim str))
      (setq lst (cons (substr str 1 ptr) lst))
      (setq str (substr str (+ ptr 2)))
    (reverse (cons str lst))
  ;; CAB 05/07/06
  ;;  group on the first two elements  A B of a flat list A B C D
  ;;  InpLst is the flat list ((A B) (C D) (E F)...)
  (defun group_on2 (InpLst / OutLst tmp grp idx sub)
    (while InpLst
      (setq OutLst (cons (list (car InpLst) (cadr InpLst)) OutLst))
      (setq InpLst (cddr InpLst))
    (reverse OutLst)
  ;; create a list of list with 4 items in each sub list
  (setq lst (apply 'append (mapcar '(lambda (x) (sparser x ",")) output)))
  ;;  convert to numbers
  (setq lst (mapcar '(lambda (x)(if (numberp (read x))(read x))) lst))
  ;;  group in pairs
  (setq lst (group_on2 (group_on2 lst)))
  ;;  Replace nil points
  ;| -=< Under Construction  >=-
  (setq idx 0)
  (while (< idx (length lst))
      ((null stpt) (setq stpt (nth idx lst)))
      ((null (cadr (nth idx lst)))
« Reply #9 on: April 17, 2007, 07:40:10 AM »
Oops, see there, I guessed wrong on the data. :-( The groups of 4 are reversed & there is an index number.
From CVS file:
("56,-,-0.62766,0.19281"
  "55,-,-0.71186,0.19281"   "54,-,-0.33241,0.69237"
  "53,-,-0.41661,0.69237"   "52,-,-0.50081,0.69237"
  "51,-,-0.83871,0.69237"   "50,-,-0.92291,0.69237"
Looks like this "56,-,-0.62766,0.19281" needs to be decoded to
 this  (0.19281  -0.62766)  (nil nil)   which are two points.
 Gotta go..
noadea
« Reply #10 on: April 17, 2007, 09:52:29 AM »
FYI
Regarding to the data in csv file:
column A : number according to square
column B : number according to circle
column C : x-coordinate of square's centre point
column D : y-coordinate of square's centre point
« Reply #11 on: April 17, 2007, 12:48:34 PM »
This does not match the drawing.
From the CVS file:
1   1    -1.4668   1.1332
 From the Drawing, Pad 1
                   BLOCK REFERENCE  Layer: "Pad"
                            Space: Model space
                   Color: 6 (magenta)    Linetype: "Continuous"
                   Handle = 326F
                  "GDM7211_VCO_TEST.Pad"
                at point, X=0'-8 9/16"  Y=0'-1 19/32"  Z=    0'-0"
                 X scale factor   1.00000
                 Y scale factor   1.00000
          rotation angle 0.0000
                 Z scale factor   1.00000
Note that x = 8.5625   y = 1.59375
Why the discrepancy?
Fatty
« Reply #12 on: April 17, 2007, 04:59:03 PM »
Alan, those coordinates are relative to
center of detail (to the crosshair)
« Reply #13 on: April 17, 2007, 05:09:30 PM »
Oh, thanks Fatty.
I never would have guessed. :?
So that means we are only interested in column A & B.
In the original post I thought the data file contained points for A & B but as we see now they contain text labels.
« Last Edit: April 17, 2007, 05:15:28 PM by CAB »
Fatty
« Reply #14 on: April 18, 2007, 08:23:38 AM »
Oh, thanks Fatty.
Alan,
I've tried to solve ir entire last weekend
with no luck
Perhaps my poor brain is not in the good
condition at the moment :-)
~'J'~
