Author Topic: I can not break my splines at the intersections.  (Read 4825 times)
Thomas 3D
« on: May 16, 2011, 11:27:05 AM »
Hello Forum,
I have sometimes big wireframes, with many intersections. I have look for a lisp routine, which can break all my "lines" in the intersection. The Lisp commands which I have found, not working really.
Sometimes my grid consists of lines, arcs, polylines and splines.
I know, I can use the Autocad command "break", but if I would use this command, then I have to do a long time.
Who can help me with my problem?
Best Regards
Thomas
Thomas 3D
Re: I can not break my splines at the intersections.
« Reply #2 on: May 17, 2011, 01:05:40 AM »
Hi Lee,
thanks for your quick help.
I tested both lisp routines, but unfortunately without success. The splines can not share in the intersections.
Do you have any idea why it did not work for me?
Thomas
« Reply #3 on: May 17, 2011, 08:40:16 AM »
The drawing you uploaded is blank for me in ACAD2006.
alanjt
  • Standby for witty remark...
« Reply #4 on: May 17, 2011, 08:47:33 AM »
No wonder he can't break the splines, they don't exist.
Dropbox
Thomas 3D
« Reply #5 on: May 19, 2011, 09:16:10 AM »
Hi Alanjt,
why do you say ->the splines don't exist.
I have open again my file, and I can see the spline. Or did you mean something else?
alanjt
« Reply #6 on: May 19, 2011, 09:29:12 AM »
Hi Alanjt,
It was a joke based on CAB's response.
Dropbox
« Reply #7 on: May 19, 2011, 10:10:31 AM »
Hi Alanjt,
I could not see the spline opened in ACAD 2006.
hmspe
« Reply #8 on: May 19, 2011, 10:40:29 AM »
When I try to break or trim the splines I get the message
Object is perpendicular to UCS XY plane.
The intersection osnap shows very few actual intersections.  Most trim routines require that the entity being trimmed has an actual intersection with the trimming line.
alanjt
« Reply #9 on: May 19, 2011, 10:42:23 AM »
Would changing the project help?
eg.
Command: tr TRIM
Current settings: Projection=UCS, Edge=Extend
Select cutting edges ...
Select objects or <select all>: Specify opposite corner: 2 found
Select objects:
Select object to trim or shift-select to extend or
[Fence/Crossing/Project/Edge/eRase/Undo]: p
Enter a projection option [None/Ucs/View] <Ucs>:
Dropbox
SOFITO_SOFT
« Reply #10 on: May 19, 2011, 10:58:01 AM »
Hello:
If you can use the discretized splines every 10 units ( for example ) , you can calculate interserccion points in a very approximate. And from them, break the entities.
That may solve your problem ?
Greetings.
