CAD Forums => CAD General => Topic started by: Andrea on February 24, 2005, 10:21:52 PM
ok there is a good one...
when i open a new or existing drawing, and load some lisp files...
is there any way to see all active variables ?
eg:
if I load a lisp and in this lisp you have this code..
(setq var1 (getvar "textsizse")
var2 (getvar "dwgname")
and the var1 and/or var2 is not set to nil after or before loading the file...
so i would like to know how many variables not set to nil can i found.
something like (PRINT ALLVARS)
var1 = 1
var2 = "drawing1.dwg"
etc...
don't know if i'm clear... :oops:
Atoms16.vlx (http://www.theswamp.org/lilly_pond/mp/lisp/atoms16.vlx?nossi=1) (compiled w/AutoCAD 2004) is gettin' a bit long in the tooth but it may provide the kind of information you're looking for.
(http://www.theswamp.org/screens/mp/atoms.png) (http://www.theswamp.org/lilly_pond/mp/lisp/atoms16.vlx?nossi=1)
Failing the above it's a relatively simple matter to walk through the atoms-family and examine each symbol: is it an int, a real, a list, a string ... (be gentle I wrote this very quickly):
(defun FindSymbols
;; FindSymbols © 2005 Michael Puckett · All Rights Reserved
;; Version · 1.0 2005/02/24 MP Original code.
;; 1.1 2005/02/25 MP Distilled / Recoded.
;; About · FindSymbols is an atoms-family scanner that
;; allows one to scan for specific data types c/w
;; with include and exclude spec ability.
;; Written · Quick and dirty for www.theswamp.org and friends.
;; Contact · cadlabs@gmail.com
;; examples
;; (progn
;; (mapcar 'print
;; (FindSymbols
;; '(int real) ;; find numeric values
;; "*" ;; include everything
;; "vl*,ac*" ;; exclude vl*,ac*
;; (princ)
;; (progn
;; (mapcar 'print
;; (FindSymbols
;; '(str) ;; find string values
;; "" ;; exclude nothing
;; (princ)
;; (progn
;; (mapcar 'print
;; (FindSymbols
;; safearray ;;
;; variant ;; find activex values
;; vla-object ;;
;; (princ)
;; data returned
;; (A INT 1)
;; (B INT 2)
;; (C INT 3)
;; (PI REAL 3.14159)
( typeList
includeFilter
excludeFilter
GetSymbolProperties
(defun GetSymbolProperties ( symbol / value )
(list
symbol
(strcase (vl-symbol-name symbol))
(type (setq value (vl-symbol-value symbol)))
value
(if (null typeList)
(setq typeList
'( ename
exrxsubr
file
int
list
pagetb
pickset
real
safearray
str
subr
sym
usubr
variant
vla-object
(setq includeFilter
(if (/= 'str (type includeFilter))
(strcase includeFilter)
(setq excludeFilter
(if (/= 'str (type excludeFilter))
(strcase excludeFilter)
(mapcar
'(lambda (x) (list (car x) (caddr x) (cadddr x)))
(vl-sort
(vl-remove-if 'null
(mapcar
'(lambda ( properties / name )
(if (member (caddr properties) typeList)
(if (wcmatch
(setq name (cadr properties))
includeFilter
(if (not
(wcmatch
name
excludeFilter
properties
(mapcar 'GetSymbolProperties
(atoms-family 0)
'(lambda (a b) (< (cadr a) (cadr b)))
I've really got to get a life.
Edit 1: Revised code.
Type LSP at the command prompt. Hope this helps.
<Long quote back deleted>
Thanks...but i can't go to the link...
ask me for a login and password...
also...i got an error when tring the code...
The login username and password is the same one you use for theSwamp. :shock:
What whdjr said above.
Also, how are you using FindSymbols, it works for me at work and home, AutoCAD 2002 / 2004 respectively.
Try this --
(progn (mapcar 'print (FindSymbols '(int real) "*" "vl*,ac*")) (princ))
What happens?
thanks..
it work ! :wink:
You're welcome; cheers.
