Mark, not mocking you..stating a fact...that the answer it gave is WRONG (confirming your observation).
Uh, it would be the 'right' software for the job, should autodesk chose to actually TEST and FIX the problems as they were discovered. Even if that discovery was made by the users, and not met with a wall of denial that problems do exists in the application.
