Author Topic: ( C3D 2008 ) Add Multiple Surface Boundaries  (Read 5614 times)
sinc
Re: ( C3D 2008 ) Add Multiple Surface Boundaries
« Reply #15 on: May 20, 2007, 06:44:12 PM »
OK, new source code and DLL are posted:
http://ejsurveying.com/sincpacc3d.htm
I went ahead and added in Feature Lines as possible entities to select, in addition to Survey Figures and Polylines.  It even seems to work fine on entities that aren't completely closed, at least in the couple that I tried.
I changed the names of the file, class, and methods a bit, to get them all more-consistent.  So the command is now called HIDEBND, and lives in a class called SincpacC3D.SurfaceBoundaries.HideBoundaries, which seemed a bit more-descriptive than MULTIHIDE.
Guest
« Reply #16 on: May 21, 2007, 09:35:00 AM »
Could you post the ZIP file here?  For some reason I can DL files from here, but not from other sites.
Thanks.
sinc
« Reply #17 on: May 21, 2007, 10:14:50 AM »
Here's the current version.
But I'd encourage others reading this post to download it from our site instead, since the SincpacC3D is in active development, and new-and-improved versions are being posted on a regular basis.  This will rapidly become an "old and decrepit version".   :-)
Guest
« Reply #18 on: May 21, 2007, 01:32:35 PM »
Tank you, berry, berry much!
