Author Topic: What is the Rotate Setting?  (Read 1980 times)
craigr
« on: June 06, 2014, 12:12:40 PM »
I have a block that when I insert it into a dwg, I give it a rotation # that I want. When I insert it, it is pointed straight up. If I want it to point Right, I give it a rotation # of 270, etc...  Even if I copy one that is rotated Right, (270), if I want the Rotated one to point straight down, I would give it the value of 180 and it would point straight down.
For some reason, in THIS dwg, the Rotation # I give it is from the rotation that it is currently at. Such as, if I have one pointed Right and I want it to point Left, I have to give it the Rotation #180 instead of #90.
What is the setting to change this back so it is the First way I described it?
craigr
Re: What is the Rotate Setting?
« Reply #1 on: June 06, 2014, 12:16:48 PM »
DVIEW >> ENTER >> TWIST >> 0.0 ??
tedg
« Reply #2 on: June 06, 2014, 12:26:05 PM »
Either that or your UCS is not at world (WCS)?
Command: UCS>> W >>[enter]
And after that, to make sure your plan is at the WCS
Command: PLAN >> [enter] [enter]
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
Cathy
« Reply #3 on: June 06, 2014, 04:52:56 PM »
On the UNITS command, there is an option to measure angles clockwise, and also the Direction button there specifies where 0deg is.  Would that affect this?
Rob...
« Reply #4 on: June 09, 2014, 07:01:28 AM »
+1
AutoCAD, by default, rotates counter clockwise. Using units, that can be changed to clockwise.
CAD Tech
