Author Topic: VLIDE Error report: Not a string inthe list: <point>  (Read 1737 times)
Daniel J. Ellis
« on: January 06, 2011, 08:56:34 AM »
Lee's tutorial has inspied me to try debugging my latest routine in VLIDE.
The error it's returning is "Not a string in the List: <point>" and I've been able to narrow it down to the following snippet:
(DEFUN CreateOffsetBoundary( hpt / hptx hpty hptx2 hpty2 hpt2 obj  )
;RECEIVES A POINT AS AN ARGUMENT, CREATES A BOUNDARY AROUND THAT POINT AND OFFSETS THAT BOUNDARY
(SETQ
hptx (CAR hpt);GET x VALUE
hpty (CADR hpt);GET y VALUE
hptx2 (+ hptx 1000);CREATE NEW x VALUE
hpty2 (+ hpty 1000);CREATE NEW y VALUE
hpt2 (LIST hptx2 hpty2);COMBINE x AND y VALUES TO SPECIFY NEW POINT
);SETQ
(COMMAND "._BOUNDARY" hpt "")
(SETQ obj (ENTLAST))
(COMMAND "OFFSET" "0.1" obj hpt2 "")
);DEFUN
Any clues?  Google and teh search here throw up blanks :(
dJE
dJE
Re: VLIDE Error report: Not a string inthe list: <point>
« Reply #1 on: January 06, 2011, 09:06:00 AM »
which line does it stop at ?
If you load the code into the VLIDE, set menu dropdown Debug->BreakOnError to ON (ticked) then load the code from the VLIDE into Autocad.
When the code stops with an error select Debug->LastBreakSource or Ctrl-F9 to display the line the error is on.
kpblc
« Reply #2 on: January 06, 2011, 09:13:53 AM »
Try this:
(defun createoffsetboundary2 (pt / )
  (if (and pt (listp pt) (>= (length pt) 2) (vl-cmdf "_.boundary" "_none" pt ""))
    (command "_.offset" 0.1 (entlast) "_none" (list (+ (car pt) 1000.) (+ (cadr pt) 1000.)) "")
    ) ;_ end of if
  ) ;_ end of defun
Another way:
(defun createoffsetboundary3 (pt / minp maxp)
      (vla-getboundingbox (vlax-ename->vla-object (entlast)) 'minp 'maxp)
      (setq maxp (vlax-safearray->list maxp))
      (command "_.offset" 0.1 (entlast) "_none" (list (+ (car maxp) 1000.) (+ (cadr maxp) 1000.)) "")
      ) ;_ end of progn
    ) ;_ end of if
  ) ;_ end of defun
« Last Edit: January 06, 2011, 09:17:27 AM by kpblc »
Sorry for my English.
Daniel J. Ellis
« Reply #3 on: January 06, 2011, 01:01:28 PM »
Doing this moves the cursor to the end of the offset line.  Is it for some reason not recognising the calculated point as a point?
dJE
dJE
« Reply #4 on: January 06, 2011, 05:04:24 PM »
I've just tested your code and it works without error for me.
I'd suggest you may have an invalid obj
try this, one statement at a time from the VLIDE by highlighting the statement and selecting "Load Selection" icon on the Vlide toolbar.
[color=green];; createoffsetboundary_inLine.lsp[/color]
    (setq hpt (getpoint [color=Maroon]"Select Point inside boundary"[/color]))
    (setq hptx  (car hpt)
          hpty  (cadr hpt)
          hptx2 (+ hptx 1000)
          hpty2 (+ hpty 1000)
          hpt2  (list hptx2 hpty2)
    (command [color=Maroon]"._-BOUNDARY"[/color] hpt [color=Maroon]""[/color])
    (setq obj (entlast))
    (command [color=Maroon]"OFFSET"[/color] 10.0 obj hpt2 [color=Maroon]""[/color])
« Last Edit: January 06, 2011, 05:15:34 PM by Kerry »
Daniel J. Ellis
« Reply #5 on: January 11, 2011, 08:53:22 AM »
When I actually ran the routine properly, rather than trying through the VLIDE, it turns out that the error wasn't in that section of routine at all <grr>
I've been using R2011, which has a wonderful feature as part of its hatch routine to specify the layer the hatch's going to be inserted on.
This is great, until you have a routine that sets the current to where you want the hatch to go to and freezes off the random layer you had been hatching on!
I'm the only one in the office using R2011 (everyone else uses R2010) so I'm going to have to start a new thread about detecting what version of ACADwin's being run ^_^
Thanks for your help, nevertheless :)
dJE
dJE
