Author Topic: Create a Filter for some Xref Layers  (Read 4745 times)
Fabricio28
« on: January 09, 2015, 12:21:48 PM »
Hi guys,
My project i have about 50 xref layers and I wanna to use just 10 of them.
I'd like to create a filter for that 10 xref layers.
I don't know how to do that.
Coul you help me please?
Regards
Re: Create a Filter for some Xref Layers
« Reply #1 on: January 09, 2015, 12:23:53 PM »
create the filter
select the layers you want to be part of it
drag them over into the filter you just made
« Reply #2 on: January 09, 2015, 04:14:54 PM »
Open layer dialog
rt-click where it says ALL
select  NEW GROUP FILTER
Click on ALL layers or in your case
with the XREF attached, an XREF file layer filter will already appear
Select the layers you want with either click+shift click
or CTRL+CLICK to build a list
hover over one of the selected layers
Left mouse button down and drag to the layer filter name you created above and release
alanjt
  • Standby for witty remark...
« Reply #3 on: January 10, 2015, 11:43:59 AM »
Did not know you could do that. Cool.
Dropbox
Fabricio28
« Reply #4 on: January 10, 2015, 01:33:30 PM »
mjfarrell,
Thank you very much!!
worked Fine. :-D
Krushert
  • FREE BEER Tomorrow!!
« Reply #5 on: January 11, 2015, 02:45:02 PM »
I did not know you could drag and drop the layers to build your filter.  very cool indeed!
If I offer a suggestion Fabricio28,  read up on the use of wild cards in your filters.  For layers that have common characters in the layer name.   Since in my world, the xref name changes from project to project, I use a wild card in front of my text layers.  I can shut off my text with one click.
Fabricio28
« Reply #6 on: January 12, 2015, 03:56:59 PM »
Interesting Krushert,
I'd like to know more about it.
Is it working in xref layers?
« Reply #7 on: January 12, 2015, 03:57:58 PM »
yes it will work for Xref layers
« Reply #8 on: January 12, 2015, 03:58:32 PM »
also look into PROPERTY based filtering as well
can filter by linetype, color, and much more
Fabricio28
« Reply #9 on: January 29, 2015, 08:09:50 AM »
Hi guys,
I've created new group filter and worked perfect!!
And the xref project I changed the xref layers colors and I added to the group.
but when I make some change in the main project, I lose all the xref layers in the group filter.
I was thinking if is possible to create a permanent filter (include xref layers) even if I change the layer color.
Is it possible?
regards
« Last Edit: January 29, 2015, 03:51:52 PM by FABRICIO28 »
« Reply #10 on: February 02, 2015, 08:41:14 PM »
You can create a property filter and for name use
That will include all layers in a Xref
Fabricio28
« Reply #11 on: February 04, 2015, 02:01:22 PM »
Could you helpe me create a property filter?
I didn't get how to use ~*|*.
Thank you
Fabricio28
« Reply #12 on: February 04, 2015, 02:08:20 PM »
I got it my friend!!
Thank you very much.
I made a little test and worked perfect!
Fabricio28
« Reply #13 on: February 06, 2015, 11:07:13 AM »
Hi Jeff,
If I include ~ isn't filter any layer.
Help me, please...
« Reply #14 on: February 06, 2015, 11:08:40 AM »
~*|* excludes XREF layers.
