CAD Forums => CAD General => Topic started by: Fabricio28 on November 13, 2015, 08:55:19 AM
Hi all,
I'd like to understand how pdsize command works.
How Can I change the point radius?
I set pdsize to 0.40 and the point size is crazy.
Regards
From the HELP (http://help.autodesk.com/view/ACD/2016/ENU/?guid=GUID-826CA91D-704B-400B-B784-7FCC9619AFB9) file. Set point to size 5 -> (setvar 'pdsize 5)
You will also need to set PDMODE (http://help.autodesk.com/view/ACD/2016/ENU/?guid=GUID-82F9BB52-D026-4D6A-ABA6-BF29641F459B) to see the correct point style.
Hi Ron,
I've ready that article about.
I don't know if I understand clear, but didn't work.
Please, take a look in my file. I think the block is crazy.
Regards
pdsize doesn't use a user defined block
are you expecting to see your block and NOT the autocad point object on the screen?
I'd like to see the point inside my block on the screen.
Your issue is the block has a scale other than 1 .. so you'd have to do the math (setvar 'pdsize (/ sizewanted blockscale)) to get whatever size you're trying to display. If you're just trying to display a circle at a fixed size, I'd define a circle within the block with a 1 unit diameter then control the size with the block scale.
So, Can't I control just the point size?
I don't wanna change the block scale, just the point.
(setvar 'pdsize
You can only have one PDSIZE so if your blocks are at different scales then no, you cannot control a uniform size.
I don't think this is possible the way you are describing it. Nodes do not behave that way. You will need another geometric representation of what you want to see. Maybe an annotative or dynamic block would suit you.
