Code Red => AutoLISP (Vanilla / Visual) => Topic started by: dubb on July 14, 2005, 04:01:40 PM
i have this reactor that triggers a lisp routine after the "plot" command..it works, but on other systems it loops twice.
let me xplain..
the lisp routine has a dialogue box with radio buttons and the user inputs the information then its written to a text file.
the reactor is loaded as a part of the lisp routine.
what happens is..the dialogue box pops up again after entering in the information.
is the the routine or the reactor thats causing this?
the reactor..it was made by jeff m..
(or jmm:plot_reactor
(setq jmm:plot_reactor (vlr-editor-reactor nil '((:vlr-commandEnded . jmm:cmdEnd)))))
(defun jmm:cmdEnd (calling cmd /)
(cond ((eq "PLOT" (strcase (car cmd))) (c:PLOG))
;you could add other commands to track and do other things here
;;end of plot reactor
I think this comes from the same issue as found in that other thread. Did you try replacing the first 2 lines with the code I showed in that thread?
(setq jmm:plot_reactor (cadr (car (vlr-reactors :vlr-editor-reactor))))
That, I believe, seemed to solve it.
I really don't have time to test this, but you might want to try adding this little snip into your acaddoc.lsp Make sure it goes before any reactors are loaded.
(vlr-remove-all)
thanks jefff...i will try this one..i think the problem was the same, i wasnt sure of the terminology so i createda new thread..thanks man.
