ModalForm Flickering while Selecting... no good..
Any idea if this got solved in AutoCAD 2008 ? or is there a workaround (using AutoCAD 2007)
If I start a solution using the autocad managed wizard I get what I am showing in the image below, and also if I have other forms open not autocad related, it becomes a mess, then if I start a library class solution and add a window form, then a simple button with the click event, I get the flickering but is minor (not too noticeably like the one in the image).
Thanks!
