Hi.
I read this thread which spark another similar idear that might be able to take advantage of if it could be done.
When im doing drawing layout stuff, occasionally i cad or see things in pairs (same blocks in pairs )
My idea is, it would be great if i could select all the of blocks, but i only want the block either on the right side, or left side, or above or below be put into a selection set.
-Block to block in each pair ~2 feet apart. (user input max distant)
-Every pair of blocks many feet apart (this is not relevant)
Another idea
Tunnel lighting (thousands of lights in one direction)
What i would like is be able to select ie. every fourth light or every fifth light (user define) to put into a selection to manipulate their layer and change it to an emergency light
