Author Topic: Rotated Text  (Read 1429 times)
Scott
Rotated Text
« on: January 28, 2005, 08:42:20 PM »
Hello all,
I have a toolbar called TSLeader.  As I'm sure you can all guess, this is a bunch of leader tools.  The problem I'm having with it is the text is rotated 90 degrees from where it should be.  All other text and dims are fine.  It only happens when I run the leaders associated with TSLeader.  Does anyone know what might be going on.  I would greatly appreciate any help offered.
Scott
pmvliet
Rotated Text
« Reply #1 on: January 28, 2005, 09:30:07 PM »
Not knowimg much about your setup. What text style do your leaders use? Is it by chance using one that have your text rotated 90 degree's?
Is your usc rotate 90 degree's?
just some thoughts...
Scott
Rotated Text
« Reply #2 on: January 30, 2005, 12:48:51 AM »
Okay, I'm the routines use the mtext command.  When I type mtext and put in my text everything is fine.  However, when I use the TSLeader command, the text comes in rotated 90 degrees.  I did find out that the TSLeader works fine in a new drawing.  So I'm guessing it is something to do with this particular drawing.
Scott
