Okay, I'm the routines use the mtext command. When I type mtext and put in my text everything is fine. However, when I use the TSLeader command, the text comes in rotated 90 degrees. I did find out that the TSLeader works fine in a new drawing. So I'm guessing it is something to do with this particular drawing.
Scott
