Author Topic: List Printer  (Read 2878 times)
List Printer
« on: June 14, 2010, 10:46:54 AM »
I needed something similar to MP's Elist function, but for general lists, so I came up with this:
(defun prt ( lst / subprt )
  ;; © Lee Mac 2010
  (defun subprt ( lst ind / pritem )
    (defun pritem ( item ind )
      (repeat ind (princ "   "))
      (if (member item '("(" ")"))
        (princ item)
        (prin1 item)
      (terpri)
    (if lst
      (if (vl-some 'vl-consp lst)
          (pritem "(" ind)
          (foreach x lst
            (if (vl-consp x)
              (if (vl-list-length x)
                (subprt x (1+ ind))
                (pritem x (1+ ind))
              (pritem x (1+ ind))
          (pritem ")" ind)
        (pritem lst ind)
  (cond (  (not lst) (princ "nil"))
        (  (eq 'ENAME (type lst))
           (subprt (entget lst) 0)
        (  (subprt lst 0))
I hope it will help someone, and of course suggestions for improvement are welcome.  :-)
« Last Edit: July 31, 2010, 11:01:53 AM by Lee Mac »
Re: List Printer
« Reply #1 on: June 14, 2010, 10:58:21 AM »
Whats the Elist function?
(Looking at code now)
Re: List Printer
« Reply #2 on: June 14, 2010, 11:02:51 AM »
hey?! My list was reformatted?! ...what did you do that for? I'm guessing that youre just reporting something back to the user right 'cause i dont really see a need for reformatting a list other then for aesthetics. Right?
Re: List Printer
« Reply #3 on: June 14, 2010, 11:06:18 AM »
Yeah, its just for reformatting for clarity - I would use it if I am debugging code with a big list structure... else the list is printed in one long line...  :|
Example:
(1 2 (3 5) (1 . 2) 1 2 (1 (2 (3 4) 2)) 1)
becomes:
   1
   2
   (3 5)
   (1 . 2)
   1
   2
      1
         2
         (3 4)
         2
   1
« Last Edit: June 14, 2010, 11:10:55 AM by Lee Mac »
Re: List Printer
« Reply #4 on: June 14, 2010, 11:08:33 AM »
I'm sure its on here somewhere elist.lsp - prints the list in almost the same format as mine, but is used for 'entget' returns...
Re: List Printer
« Reply #5 on: June 14, 2010, 11:10:13 AM »
Ah, well, good job. Carry on.
Re: List Printer
« Reply #6 on: June 14, 2010, 11:27:54 AM »
VovKa
  • Ukraine
Re: List Printer
« Reply #7 on: June 15, 2010, 02:37:41 AM »
(defun pprint (lst ind)
  (strcat ind
 "(\n"
 (apply 'strcat
(mapcar (function (lambda (e)
    (if (and e (listp e) (vl-list-length e) (vl-some 'listp e))
      (pprint e (strcat ind " "))
      (strcat ind " " (vl-prin1-to-string e) "\n")
lst
 ind
 ")\n"
(princ (pprint '(1 2 (3 5) (1 . 2) 1 2 (1 (2 (3 4) 2)) 1) ""))
i use something of this kind to write formatted xml files
