Author Topic: connect blocks with line  (Read 5812 times)
todor
  • Mosquito
« on: August 04, 2015, 06:14:33 AM »
greeting.
does anyone have a lisp that when selects blocks connects them with a line or polyline.
thank you
ribarm
  • Marko Ribar, architect
Re: connect blocks with line
« Reply #1 on: August 04, 2015, 06:46:48 AM »
You have to have some rule for making connections... Order of selected blocks can vary - you have to provide exact order for which connections should be performed... Or you just want to pick blocks one by one?
M.R. on Youtube
todor
  • Mosquito
« Reply #2 on: August 04, 2015, 06:55:48 AM »
For now it is enough that the coupling is carried out one by one,  selects 1, 2,3, 4,5 ... and are binding 1-2-3-4-5-6 etc.
Th.
Tharwat
  • Hypersensitive
« Reply #3 on: August 04, 2015, 08:12:06 AM »
Something like this ?
  1. (defun c:Test (/ s p ss q 1p gr)
  2.   ;;    Tharwat 04.Aug.2015     ;;
  3.   (princ "\nPick on the first Block :")
  4.   (if (setq s (ssget "_+.:S:E" '((0 . "INSERT"))))
  5.     (progn
  6.       (princ "\nNext Block :")
  7.       (while (setq ss (ssget "_+.:S:E" '((0 . "INSERT"))))
  8.         (setq p (cdr (assoc 10 (entget (ssname s 0)))))
  9.         (while (and s ss (eq 5 (car (setq gr (grread t 15 0)))))
  10.           (redraw)
  11.           (setq q (cdr (assoc 10 (entget (ssname ss 0)))))
  12.           (if (or (equal (car p) (car q) 1e-4)
  13.                   (equal (cadr p) (cadr q) 1e-4)
  14.                   )
  15.             (grvecs (list -3 p q))
  16.             (if
  17.               (minusp
  18.                 (sin
  19.                   (-
  20.                     (angle
  21.                       p
  22.                       q
  23.                       )
  24.                     (angle q (cadr gr))
  25.                     )
  26.                   )
  27.                 )
  28.                (grvecs
  29.                  (list -3 p (setq 1p (list (car q) (cadr p) 0.)) 1p q)
  30.                  )
  31.                (grvecs
  32.                  (list -3 p (setq 1p (list (car p) (cadr q) 0.)) 1p q)
  33.                  )
  34.                )
  35.             )
  36.           )
  37.         (if (eq (car gr) 3)
  38.           (if (and p 1p q)
  39.             (mapcar
  40.               '(lambda (j k)
  41.                  (entmake (list '(0 . "LINE") (cons 10 j) (cons 11 k)))
  42.                  )
  43.               (list p 1p)
  44.               (list 1p q)
  45.               )
  46.             (if (not (zerop (distance p q)))
  47.               (entmake (list '(0 . "LINE") (cons 10 p) (cons 11 q)))
  48.               )
  49.             )
  50.           )
  51.         (redraw)
  52.         (setq 1p nil
  53.               s  ss
  54.               )
  55.         )
  56.       )
  57.     )
  58.   (princ)
  59.   )
todor
  • Mosquito
« Reply #4 on: August 04, 2015, 08:17:09 AM »
Yes, work.
But line two blocks should be connected with a line or polyline at the shortest distance
Th.
Tharwat
  • Hypersensitive
« Reply #5 on: August 04, 2015, 08:21:24 AM »
Yes, work.
Th.
Sorry , not clear enough to me .
Explain a bit further .
andy_lee
« Reply #6 on: August 04, 2015, 08:25:40 AM »
Tharwat ,good man !
Here is a way ,code by Alan
  1. ; http://www.theswamp.org/index.php?topic=33469.0
  2. (defun c:OC (/ _sel lst pt)
  3.   ;; Connect objects (by insertion point)
  4.   ;; Alan J. Thompson, 05.22.10
  5.   (defun _sel (pnt msg / gr e pt)
  6.     (while (and (setq gr (grread T 15 2))
  7.                 (/= (car gr) 25)
  8.                 (not (vl-position (cadr gr) '(13 158)))
  9.                 (not e)
  10.            )
  11.       (redraw)
  12.       (and pnt (grdraw (trans pnt 0 1) (cadr gr) 1 -1))
  13.       (princ (strcat "\r" msg))
  14.       (if (and (eq 3 (car gr))
  15.                (setq e (ssget (cadr gr)))
  16.                (setq e (entget (ssname e 0)))
  17.                (not (wcmatch (cdr (assoc 0 e)) "*LINE*,ARC,*TEXT*"))
  18.                (setq pt (cdr (assoc 10 e)))
  19.           )
  20.         pt
  21.         (setq e nil)
  22.       )
  23.     )
  24.   )
  25.
  26.   (if (car (setq lst (list (_sel nil "Select object: "))))
  27.     (while (setq pt (_sel (car lst) "Select next object: "))
  28.       (if (equal pt (car lst))
  29.         (alert "Same object as previous!")
  30.         (progn (setq lst (cons pt lst))
  31.                (entmakex (list '(0 . "LINE") (cons 10 (cadr lst)) (cons 11 (car lst))))
  32.         )
  33.       )
  34.     )
  35.   )
  36.   (redraw)
  37.   (princ)
  38. )
  39.
andy.
Best regards.
andy_lee
« Reply #7 on: August 04, 2015, 08:42:58 AM »
andy.
Best regards.
Tharwat
  • Hypersensitive
« Reply #8 on: August 04, 2015, 08:59:54 AM »
Tharwat ,good man !
Thank you Andy  :wink:
andy_lee
« Reply #9 on: August 04, 2015, 09:09:23 AM »
andy.
Best regards.
mianbaoche
« Reply #10 on: August 04, 2015, 09:31:50 AM »
And some reference here:
http://www.theswamp.org/index.php?topic=30434.0
 using the improved genetic algorithm。Great!
todor
  • Mosquito
« Reply #11 on: August 05, 2015, 03:35:05 AM »
Thanks.
tanvirme2k9
« Reply #12 on: August 10, 2015, 09:49:59 PM »
andy_lee : "Here is a way ,code by Alan"
Is it possible to draw polyline instead of line?
tedg
« Reply #13 on: August 11, 2015, 10:31:16 AM »
Change .line to .pline ? (didn't test it, just a guess)
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
tanvirme2k9
« Reply #14 on: August 12, 2015, 12:33:26 AM »
Changing '. line' to '.pline' doesn't work  :-(
« Last Edit: August 12, 2015, 04:59:36 AM by tanvirme2k9 »
