Author Topic: Determine orientation of linear parameter in dynamic block  (Read 2734 times)
TimAshby
« on: March 06, 2015, 04:05:27 PM »
I'm looking to create a version of the stretch command that works on dynamic blocks with linear parameters - I figure that to do this, I'd need to work out which way a parameter was pointing in the block, ie I dont want a vertical move being triggered by a horizontal stretch command!
I've gotten as far as Lee's dump dynamic properties code - this dumps a bunch of properties, one of which is the origin of the parameter, one of which is the value. None of which is the endpoint! Doing a dump on the parameter while in the block editor suggests that I should be able to (vla-get-endpoint), but passing one of the parameter objects from (vlax-invoke 'getdynamicproperties) gives an error. Cycling thro' the collection of VLA-objects shows only the lines, polylines etc.
Has anyone got any clever ideas?
Cheers!
mailmaverick
Re: Determine orientation of linear parameter in dynamic block
« Reply #1 on: March 08, 2015, 01:16:32 PM »
Kindly attached your DWG file containing the dynamic block.
TimAshby
« Reply #2 on: March 09, 2015, 04:37:32 AM »
I'm looking to create a command that stretches any dynamic block - it's not a problem with a specific block :-)
mailmaverick
« Reply #3 on: March 09, 2015, 07:55:43 AM »
I agree to what you say but for developing a lisp, a sample block is needed. Also send the initial block and what it should be after running the lisp.
