We got a job platting a 280-lot subdivision. It's the first time I've worked on something that large. Asking around about how to go about this, I've gotten "Use LDD Parcel Manager" as the response. Some people would start to tell me about the "Break Lines" command, and how useful it was. I even tried asking the "best expert" of a couple of other companies, and got the same answers. I figured there MUST be a better way.
So, I decided to try starting up Map for the first time. I probably spent about three days trying to figure it out. Using queries was an entierely different way of working with Autocad, and it took a while to get through the mechanics of it all. It didn't help any that the Map tutorials seem to pretty much suck.
In the end, though, I figured out how to use centroids and polygon topographies, drawing cleanup, object data, and map annotations. In the end, I was able to calculate and label the lot number and area of all 290 lots all at once. It was a good thing I figured this out, too, because just as I finished, the client decided they wanted more "medium-sized" lots in the subdivision, and changed over half of it. I figured the best thing to do was start over.
The second time, since I now had an idea of how to do things, I was able to cleanup the linework and get all lots labeled with lot number and area in three hours. Keep in mind that I'm a Map newbie, so this was probably pretty slow. (I suspect I could do it again in an hour.) If I had used Parcel Manager, I figure it would have taken me at LEAST three days, and in the end I wouldn't be entirely sure there were no errors.
But then here's the real kicker: the client then wanted to make a minor change that involved moving the lines of 10 lots by a foot toward the south. I discovered that, by editing the topology, all I had to do was pick the 10 lines and specify which direction to move the lines. All lot areas were automatically recalculated for me, even though one edge of the lots was on a curve. All I had to do was update the annotations. This simple edit would have taken me an hour to do with Parcel Manager, and instead it took me five minutes.
Just thought I'd mention this, in case anyone else out there has been ignoring Map. I've barely scratched the surface, and I can already save days over LDD's way of doing at least this one task...
Unfortunately, it still takes a long time to get all those lines and curves labeled with bearings/distances/deltas/radii etc....
