Author Topic: Break symbol lisp  (Read 2127 times)
CadFrank
Break symbol lisp
« on: November 07, 2011, 03:07:09 PM »
Hi, I would like to know if a lisp of a break symbole existe where you can input a break symbole at each division.
Command: breakline
Block= BRKLINE.DWG, Size= 3, Extension= 1.5
Specify first point for breakline or [Block/Size/Extension]:
Specify second point for breakline:
Specify location for break symbol <Midpoint>:
i would like a command like this.
Command: breakline
Specify location for break symbol <divide>:
you can go at this forum if you want more explination on what i want
http://www.cadtutor.net/forum/showthread.php?63986-Breakline-lisp-usine-a-divide-in-section
Re: Break symbol lisp
« Reply #1 on: November 07, 2011, 03:35:03 PM »
Welcome to the Swamp Frank.
None that I have seen.
You may like this one: http://www.theswamp.org/index.php?topic=37531.0
Not to your specifications but you can scale the break symbol & extend the ends with the + or - keys.
CadFrank
« Reply #2 on: November 07, 2011, 03:52:42 PM »
I just want to be able to create multi break symbol at the same time. I guess ill have to creat my own lisp when i take a lisp cours in a month.
Thanks alot anyways.
« Reply #3 on: November 08, 2011, 11:35:38 AM »
To get exactly what you want, yes you will need to roll your own.
Selecting the one circled below will allow you to use the + and - keys to add symbols
and moving the mouse will scale the symbols.
