Author Topic: Still command reactor and xdata  (Read 1784 times)
Lupo76
« on: February 23, 2012, 08:27:19 AM »
Maybe this time I ask too much, but I trust in your readiness.
This topic, perhaps it is the continuation of this: http://www.theswamp.org/index.php?topic=40880.0
I decided to open a new topic because the request is slightly different.
Thanks to the previous topic and all your tips I wrote the following code.
Practically loading it in the file TEST.dwg that enclose, when gate one or more lines is output an alert with the contents of a xdata stored within the lines.
I modified the code as I read the same xdata even when I use the stretch command.
(defun C:CmdOn () (Vlr_Cmd t))
(defun C:CmdOff () (Vlr_Cmd nil))
(setq *CmdEraseDebug* t)
(defun Vlr_Cmd (mode)
 (and *orEra (vlr-added-p *orEra) (vlr-remove *orEra)) ; only on during the erase command
 ;; (and *orApp (vlr-added-p *orApp) (vlr-remove *orApp)) ; only on during the erase command
   (mode
     ;; Load only once, if already loaded reactivate it if inactive
     (and *vlr-CWS (not (vlr-added-p *vlr-CWS)) (vlr-add *vlr-CWS))
     (and *vlr-CE  (not (vlr-added-p *vlr-CE))  (vlr-add *vlr-CE))
     (and *vlr-CC  (not (vlr-added-p *vlr-CC))  (vlr-add *vlr-CC))
     (or *vlr-CWS
        (setq *vlr-CWS (vlr-command-reactor nil '((:vlr-commandwillstart . CmdStartCommand)))))
     (or *vlr-CE
        (setq *vlr-CE (vlr-command-reactor nil '((:vlr-commandEnded . CmdEndCommand)))))
     (or *vlr-CC
        (setq *vlr-CC (vlr-command-reactor nil '((:vlr-commandCancelled . CmdCancelCommand)))))
     (princ "\nCommand Reactor is ON!")
     (or *orEra (setq *orEra (vlr-acdb-reactor nil '((:vlr-objecterased . _ObjErased)))))
     ;; (or *orApp (setq *orApp (vlr-acdb-reactor nil '((:vlr-objectappended . _ObjAdded)))))
   ;;  Turn the reactors off
   (t
     (and *vlr-CWS (vlr-added-p *vlr-CWS) (vlr-remove *vlr-CWS))
     (and *vlr-CE (vlr-added-p *vlr-CE) (vlr-remove *vlr-CE))
     (and *vlr-CC (vlr-added-p *vlr-CC) (vlr-remove *vlr-CC))
     (princ "\nCommand Reactor is OFF!")
(defun CmdStartCommand (Call CallBack / ssErase slen)
 (if (OR
        (= (strcase (car CallBack)) "ERASE")
        (= (strcase (car CallBack)) "STRETCH")
       (and *orEra (not (vlr-added-p *orEra)) (vlr-add *orEra)) ; trun on during the erase command
       ;; (and *orApp (not (vlr-added-p *orApp)) (vlr-add *orApp)) ; trun on during the erase command
       (setq *EraseStarted* t
             *IDlst nil)
       (if (setq ssErase (cadr(ssgetfirst)))
         (setq slen (sslength ssErase))
         (setq slen 0)
       (and *CmdEraseDebug*
            (alert (strcat "Erase Started with " (rtos slen 2 0) " items selected.")))
(defun CmdEndCommand (Call CallBack / slen ent)
 (if (= (strcase (car CallBack)) "ERASE")
     (and *orEra (vlr-added-p *orEra) (vlr-remove *orEra)) ; turn OFF
     ;; (and *orApp (vlr-added-p *orApp) (vlr-remove *orApp)) ; turn OFF
     (setq *EraseStarted* nil) ; reset Erase command flag
     (if (and *ErasedList (> (length *ErasedList) 0))
       (setq slen   (length *ErasedList))
       (setq slen 0)
     (foreach ent *ErasedList
       (setq *IDlst (cons (get-xdata ent "NAMEAPP" "ID") *IDlst))
     (setq *ErasedList nil)
    (if (/= *IDlst nil)
      (foreach el *IDlst
        (if el (alert (strcat "ID = " el)))
  (if (= (strcase (car CallBack)) "STRETCH")
       (setq slen 0)
       (setq *IDlst (cons (get-xdata_stretch ent "NAMEAPP" "ID") *IDlst))
    (if (/= *IDlst nil)
      (foreach el *IDlst
(defun CmdCancelCommand (Call CallBack)
 (if (OR
     ;; (and *orApp (not (vlr-added-p *orApp)) (vlr-remove *orApp)) ; turn OFF
     (and *CmdEraseDebug* (princ "\nErase command canceled."))
;;  If ERASE command then collect ename of all erased entities
(defun _ObjErased (a b / delent)
  (if *EraseStarted*  ; flag for ERASE command started
      ;;  may not be necessary but check the ent list to be
      ;;  sure the ename is not there already
      ;;(if (not (vl-position (cadr b) *ErasedList)) (progn
        (setq *ErasedList (cons (cadr b) *ErasedList)) ; collect the ename
      ;;  >>---> message to command line
           (princ (strcat "\n" (vl-princ-to-string (cadr b)) " Deleted From Drawing")))
      ;;  <---<<  end message
(defun get-xdata (ogg nomeapp labeldato / nX exlist thexdata sublista labelfind dato)
      (entdel ogg)
      (setq nX 0)
      (setq exlist (assoc -3 (entget ogg (list nomeapp))))
      (if (/= exlist nil)
             (setq thexdata (cdr (car (cdr exlist))))
             (setq sublista (nth nX thexdata))
             (if sublista
                 (setq labelfind (splittae (cdr sublista) "=" 0))
                 (setq labelfind nil)
             (while (/= labelfind nil)
              (if (= labelfind labeldato)
                      (if sublista (setq dato (splittae (cdr sublista) "=" 1)))
                     (setq nX (+ nX 1))
                     (if sublista
             (setq dato dato)
      (entdel ogg)
      (if dato dato)
(defun get-xdata_stretch (ogg nomeapp labeldato / nX exlist thexdata sublista labelfind dato)
      (entdel ogg)
      (setq nX 0)
      (if (/= exlist nil)
             (if sublista
                     (setq nX (+ nX 1))
                     (if sublista
             (setq dato dato)
      (entdel ogg)
      (if dato dato)
(defun splittae (str delim numerostringa / ptr lst el_stringhe)
  (while (setq ptr (vl-string-search delim str))
    (setq lst (cons (substr str 1 ptr) lst))
    (setq str (substr str (+ ptr 2)))
  (setq el_stringhe (reverse (cons str lst)))
  (length el_stringhe)
  (if (>= (- (length el_stringhe) 1) numerostringa)
    (nth numerostringa el_stringhe)
    nil
(C:CmdOn)
As mentioned it works very well with the command erases, but with the stretch command does not work.
The code that I changed is that the function "CmdEndCommand"
Can you give me some idea?
Thank you.
