Author Topic: AMEP Project Properties?  (Read 1683 times)
MexicanCustard
« on: May 26, 2011, 01:53:34 PM »
Does anybody know how to get the Project Properties, via .NET, set up in AMEP's Project Manager? What I'm trying to get is the floor levels so I can tell if a pipe is drawn above or below the current floor.
Re: AMEP Project Properties?
« Reply #1 on: May 26, 2011, 03:18:31 PM »
See if you can add anymore for each loops in this
        [CommandMethod("ProjectLevels")]
        public void ProjectLevels()
            Database db = doc.Database;
            Editor ed = doc.Editor;
            ProjectBaseManager pjtBaseMgr = ProjectBaseServices.Service.ProjectManager;
            ProjectFileName pjtFileName = pjtBaseMgr.CurrentProjectFileName;
            Project pjt = pjtBaseMgr.OpenProject(OpenMode.ForRead, pjtFileName.Path);
            ProjectConfiguration pjtConfig = pjt.Configuration;
            ProjectFile pjtFile = pjt.GetFile(db);
            foreach (ProjectRegion pjtReg in pjtFile.Regions)
                uint[] levelids = pjtReg.LevelIds;
                foreach (uint levelid in levelids)
                    foreach (ProjectLevel pjtLvl in pjtConfig.Levels)
                        if (pjtLvl.Id == levelid)
                            //pjtLvl.CutPlaneHeight;
                            //pjtLvl.Description;
                            //pjtLvl.Elevation;
                            //pjtLvl.Height;
                            //pjtLvl.Name;
                            //etc............
MexicanCustard
« Reply #2 on: May 26, 2011, 04:05:19 PM »
LOL, will do.
Thanks! Exactly what I was looking for.
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #3 on: May 26, 2011, 06:48:50 PM »
Interesting that the pjtReg.LevelIds  are uint
Called Kerry in my other life
I live at UTC + 13.00
