Author Topic: Stringless Rounds?  (Read 8777 times)
David Bethel
Stringless Rounds?
« Reply #15 on: November 10, 2004, 08:32:30 AM »
Taking Michael's approach and appling to my code, you get:
;;;ROUND BY
;;;ARG -> REAL to round, REAL to round by
;;;RET -> REAL
(defun rndby (r b / tmp)
  (setq tmp (rem r b))
  (cond ((>= tmp (* 0.5 b))  (+ r (- b tmp)))
        (T                   (- r tmp))))
A fairly clean piece of code.  -David
R12 Dos - A2K
Stringless Rounds?
« Reply #16 on: November 10, 2004, 12:17:17 PM »
Got my last routine to work with neg number as well as positive ones.
; positive or negative numbers with variable break point
(defun rndup (num Brk)
  (float (fix (+ num (* (/ num (abs num))(- 1 brk))))))
(defun c:test()
  (print (rndup 2.2 0.2))
  (print (rndup 2.3 0.3))
  (print (rndup -2.5 0.3))
  (print (rndup -2.2 0.3))
daron
Stringless Rounds?
« Reply #17 on: November 10, 2004, 01:52:53 PM »
David, that's exactly what I tried. Maybe I need to exactly try it again. I'm sure I didn't do it right.
David Bethel
Stringless Rounds?
« Reply #18 on: November 10, 2004, 02:37:01 PM »
Daron, Mark
You could also make it an (if) statement in lieu of (cond)
  (if (>= tmp (* 0.5 b))
      (+ r (- b tmp))
      (- r tmp)))
-David
R12 Dos - A2K
ImaJayhawk
Stringless Rounds?
« Reply #19 on: November 10, 2004, 05:41:20 PM »
Can you use vla-eval to call the VBA Round function?
--ImaJayhawk
daron
Stringless Rounds?
« Reply #20 on: November 11, 2004, 08:05:06 AM »
Wouldn't know, but I believe there have been a number of ways to skin this cat as I've asked.
Stringless Rounds?
« Reply #21 on: November 14, 2004, 12:21:12 AM »
Speaking of skinning cats ;
(defun our:RoundTo (value to-prec)
  (setq to-prec (abs to-prec))
  (* to-prec
     (fix (/ ((if (minusp value) - + )
               value
               (* to-prec 0.5)
             to-prec
It makes me a little self-conscious to admit how old this is.
