Author Topic: Write and read Xrecord  (Read 2712 times)
krkec
« on: October 30, 2013, 06:38:37 AM »
Could someone tell me why it wont work??
I am trying to write and read Xrecord.
namespace kec_tools
    public partial class Form1 : Form
        #region funkcije
        private bool checkXrecord(String objekt)
            Document mydoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database madata = mydoc.Database;
            Editor myed = mydoc.Editor;
            using (Transaction trans = madata.TransactionManager.StartTransaction())
                DBDictionary nod = (DBDictionary)trans.GetObject(madata.NamedObjectsDictionaryId, OpenMode.ForRead);
                if (nod.Contains(objekt))
                    return true;
                else
                    return false;
        private void writeXrecord(String txt, int num)
            /*if (checkXrecord("ViskoOPT"))
                DBDictionary nod = (DBDictionary)trans.GetObject(madata.NamedObjectsDictionaryId, OpenMode.ForWrite);
                Xrecord myXrecord = new Xrecord();
                myXrecord.Data = new ResultBuffer(
                    new TypedValue((int)DxfCode.Text, txt),
                    new TypedValue((int)DxfCode.Int16, num));
                nod.SetAt("ViskoOPT", myXrecord);
                trans.AddNewlyCreatedDBObject(myXrecord, true);
        private void readXrecord()
                ObjectId myDataId = nod.GetAt("ViskoOPT");
                Xrecord myXrecord = (Xrecord)trans.GetObject(myDataId, OpenMode.ForRead);
                List<TypedValue> polje = new List<TypedValue>(2);
                foreach (TypedValue value in myXrecord.Data)
                    polje.Add(value);
                int a = (int)polje[1].Value;
                String output = (String)polje[0].Value+ a.ToString();
                MessageBox.Show(output);
        #endregion
        public Form1()
            InitializeComponent();
        private void button1_Click(object sender, EventArgs e)
            writeXrecord("This works!!!!", 1);
            readXrecord();
Bert
Re: Write and read Xrecord
« Reply #1 on: October 30, 2013, 06:52:46 AM »
Was it because you got a 'eLock' voilation in your writeXrecord-method ?
you can solve this by using mydoc.LockDocument() in the right place :
http://www.theswamp.org/index.php?topic=14378.0
Code - Text: [Select]
  1. using (DocumentLock @lock = mydoc.LockDocument()) {
  2.         using (Transaction trans = madata.TransactionManager.StartTransaction()) {
  3.                 // Your code here...
  4.         }
  5. }
Also your readXrecord cannot find "ViskoOPt" because you did not commit the changes you made in your transaction in your writeXrecord-method.
(Add trans.Commit();)
  1. private void writeXrecord(String txt, int num)
  2. {
  3.         Document mydoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
  4.         Database madata = mydoc.Database;
  5.         Editor myed = mydoc.Editor;
  6.         //lock your document for during this transaction
  7.         using (DocumentLock @lock = mydoc.LockDocument()) {
  8.                 using (Transaction trans = madata.TransactionManager.StartTransaction()) {
  9.                         DBDictionary nod = (DBDictionary)trans.GetObject(madata.NamedObjectsDictionaryId, OpenMode.ForWrite);
  10.                         Xrecord myXrecord = new Xrecord();
  11.                         myXrecord.Data = new ResultBuffer(new TypedValue(Convert.ToInt32(DxfCode.Text), txt), new TypedValue(Convert.ToInt32(DxfCode.Int16), num));
  12.                         nod.SetAt("ViskoOPT", myXrecord);
  13.                         trans.AddNewlyCreatedDBObject(myXrecord, true);
  14.                         //commit your transaction
  15.                         trans.Commit();
  16.                 }
  17.         }
  18. }
« Last Edit: October 30, 2013, 06:58:18 AM by Bert »
n.yuan
« Reply #2 on: October 30, 2013, 09:49:34 AM »
It is not a good practice to directly write data (XRecord) into NamedDictionary at database level. If you need to store data into NamedDictionary, you'd better create a new DBDictionary underneath the database-level NamedDictionary with a unique key following a good naming convention.
If you use some database browsing tool, such as MgdDB tool, you can see there are many DBDictionary entries in database-level NameDictionary, some are built-in for vanilla AutoCAD, some are for AutoCAD vertical cousins, some are from third party tools. Create your own DBDictionary underneath the top-level NamedDictionary and only mess it up inside your own dictionary.
dgorsman
« Reply #3 on: October 30, 2013, 10:21:09 AM »
^ +1
Makes life much easier when you only have to worry about your own container.  If necessary (and I find it usually is) there can be dictionaries inside dictionaries (inside dicitonaries) to keep everything well organized.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
krkec
« Reply #4 on: October 31, 2013, 02:15:35 AM »
Thanks guys I tryed Berts solution and it works, but i will try other solutions
krkec
« Reply #5 on: October 31, 2013, 02:19:26 AM »
where can i find MgdDB tool. I google it but i cant find it
MexicanCustard
« Reply #6 on: October 31, 2013, 07:43:57 AM »
