Author Topic: Bitmap pixel color change  (Read 3355 times)
mohnston
  • CAD Programmer
« on: May 14, 2007, 07:08:58 PM »
I've got a bitmap that I want to change two colors in.
I want to change black pixels to white and vice-verse.
After iterating the bitmap one pixel at a time using getpixel and setpixel I found that it was too slow for my needs.
I found another way that I would like to try but it is a bit over my head.
Here is what I have so far:
        private Bitmap SetBlackBackground(Bitmap aBmp)
            Bitmap bmp = aBmp;
            System.Drawing.Imaging.PixelFormat pxf = System.Drawing.Imaging.PixelFormat.Format32bppRgb;
            Rectangle rect = new Rectangle(0, 0, bmp.Width, bmp.Height);
            System.Drawing.Imaging.BitmapData bmpData =
                bmp.LockBits(rect, System.Drawing.Imaging.ImageLockMode.ReadWrite, pxf);
            IntPtr ptr = bmpData.Scan0;
            int numBytes = bmp.Width * bmp.Height * 3;
            byte[] rgbValues = new byte[numBytes];
            int g = 0;
            int b = 0;
            // BREAKS ON THE NEXT LINE
            Marshal.Copy(ptr, rgbValues, 0, numBytes);
            for (int counter = 0; counter < rgbValues.Length; counter += 3)
                g = counter + 1;
                b = counter + 2;
                if ((rgbValues[counter] == 255) & (rgbValues[g] == 255) & (rgbValues[b] == 255))
                    rgbValues[counter] = 0;
                    rgbValues[g] = 0;
                    rgbValues[b] = 0;
                else
                    if ((rgbValues[counter] == 0) & (rgbValues[g] == 0) & (rgbValues[b] == 0))
                        rgbValues[counter] = 255;
                        rgbValues[g] = 255;
                        rgbValues[b] = 255;
            Marshal.Copy(rgbValues, 0, ptr, numBytes);
            bmp.UnlockBits(bmpData);
            return bmp;
The code breaks where indicated above.
The error says "Attempted to read or write protected memory".
This is my first encounter with "Marshal" so I'm not sure where to start looking for the error.
Don't be shy.
CAD Programming Solutions
Re: Bitmap pixel color change
« Reply #1 on: May 14, 2007, 09:05:44 PM »
No Idea Mark, Sorry.
A side note : Do you need the 'Allow unsafe Code' option toggled on for Marshal to work.?
MickD
« Reply #2 on: May 14, 2007, 09:29:01 PM »
Have a look at this link, looks like it may be of use.
<edit>note, that is an unsafe method, If I can dig up my Petzolds' for C# I'll see if I can find something more suitable for .net, I remember seeing it in there somewhere.
hth
« Last Edit: May 14, 2007, 09:34:13 PM by MickD »
- John Carmack
- J.R.R. Tolkien
It's Alive!
  • Retired
  • AKA Daniel
« Reply #3 on: May 14, 2007, 09:50:11 PM »
Also have a look at the samples in  http://msdn2.microsoft.com/en-us/library/ms146635.aspx
mohnston
  • CAD Programmer
« Reply #4 on: May 15, 2007, 12:43:18 PM »
Thanks for your responses.
Here is code that works for an AutoCAD thumbnail bitmap:
            Bitmap bmp = aBmp;
            System.Drawing.Imaging.PixelFormat pxf = System.Drawing.Imaging.PixelFormat.Format32bppArgb;
            int numBytes = (bmp.Width * bmp.Height) * 4;
            int g = 0;
            int b = 0;
            for (int counter = 0; counter < rgbValues.Length; counter += 4)
                g = counter + 1;
                b = counter + 2;
                    rgbValues[g] = 0;
                    rgbValues[b] = 0;
                else
                        rgbValues[g] = 255;
                        rgbValues[b] = 255;
            return bmp;
I changed the pixelformat and the counter increment.
It is much MUCH faster than getpixel/setpixel.
This method is misnamed. It doesn't set the background to black but instead inverts black and white.
It will not work with all bitmap formats but it could be easily be adjusted to handle them.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #5 on: May 15, 2007, 03:26:26 PM »
See if this will blow up your computer
using System;
using System.Drawing;
using System.Runtime.InteropServices;
using System.Drawing.Imaging;
namespace bitmapstauuf
  public class bmpstuff
    //NOTE: UNSAFE WEAR PROTECTION
    public unsafe Bitmap SetBlackBackground(Bitmap obmp)
      Bitmap abmp = new Bitmap(obmp);
      BitmapData bmpData = abmp.LockBits(new Rectangle(0, 0, abmp.Width, abmp.Height),
                            ImageLockMode.ReadWrite, PixelFormat.Format32bppArgb);
      byte* ptr = (byte*)bmpData.Scan0;
      for (int i = 0; i < bmpData.Height; i++)
        for (int j = 0; j < bmpData.Width; j++)
          byte b = ptr[0];
          byte g = ptr[1];
          byte r = ptr[2];
          if (((b == 255) & (g == 255)) & (b == 255))
            b = g = r = 0;
          else if (((b == 0) & (g == 0)) & (r == 0))
            b = g = r = 255;
          ptr += 3;
        ptr += bmpData.Stride - (bmpData.Width * 3);
      abmp.UnlockBits(bmpData);
      return abmp;
edit: return a new bmp;
« Last Edit: May 15, 2007, 03:34:39 PM by Danielm103 »
It's Alive!
  • Retired
  • AKA Daniel
« Reply #6 on: May 15, 2007, 10:07:49 PM »
Nope that didn't work :oops:
It's Alive!
  • Retired
  • AKA Daniel
« Reply #7 on: May 15, 2007, 10:36:25 PM »
Fixed,
          byte b = ptr[0];
          byte g = ptr[1];
          byte r = ptr[2];
          if (b == 255 & g == 255 & r == 255)
            ptr[0]= ptr[1]= ptr[2] = 0;
          else if (b == 0 & g == 0 & r == 0)
            ptr[0] = ptr[1] = ptr[2] = 255;
          ptr += 4;
      return abmp;
idea was from http://www.bytemycode.com/snippets/snippet/412/
« Last Edit: May 15, 2007, 10:45:13 PM by Danielm103 »
