edit kdub-> formatting to code=cadlisp-7
fix title spelling
- Thanks kdub I believe that it is better than before
- see my sign
Can you try again to explain your problem.
ie
I expect this : < example>
I get this : < example >
From a quick perusal, the code should work without fault.
- The code working without fault, and I asking for comments
- I tried again and working well.
And faced another issue, I want to replace a part of path with another part
Full path
\\10.120.200.11\projects\GEN\3120B01\BASE\Col-Grids&SE\3120B01-XCOFO.dwg
I want to replace
with
X:\
