Author Topic: Get data from loaded CTB in AutoCAD?  (Read 1314 times)
Peter2
« on: December 16, 2016, 04:24:23 PM »
If I have an opened drawing with an attached / current / loaded CTB-file, is it possible to access the content of the CTB? For example "show me the line width of colour red in that CTB"?
(There are some postings here, 10 years old, which talk about the external solution - "remove the header and use zlib to unpack". I wonder if there are some new possibilities now...)
Peter
Peter
BricsCAD V23
roy_043
  • BricsCAD 18
Re: Get data from loaded CTB in AutoCAD?
« Reply #1 on: December 17, 2016, 05:10:09 AM »
Related post (using the same technique though):
https://www.theswamp.org/index.php?topic=41648.msg467634#msg467634
Peter2
« Reply #2 on: December 17, 2016, 05:44:37 AM »
@roy_043
looks great - thank you   :-)
Peter
BricsCAD V23
Dave M
« Reply #3 on: December 19, 2016, 05:14:10 PM »
I go to this website and print the contents to a PDF.
www.xcad.ch/tests/ctbviewer.php
Cheers
Civil 3D 2018 - Microstation SS4 - Windows 10 - Dropbox
